EtherChannel Configuration for 1841 Router
michel_douglas
Can somebody help me with the configuration for configuring etherchannel on the two Vlan interfaces(101,102) i have created on my cisco 1841 router.
Anand Narayana
Level 6
Level 6
Etherchannel can be configured only on physical interfaces & not on VLAN interfaces.
hey anandanarayana,
thanks for that reply but i have a HWIC 4ESW module inserted which has 4 physical FE interfaces on it. can i configure the ports on this odule for Etherchannel???if yes kindly let me know the configuration.
Hi Michel,
Etherchannel is not supported on HWIC 4ESW. Refer to below document for more info:
http://www.cisco.com/en/US/products/ps5854/products_qanda_item0900aecd802a9470.shtml
As Suryakant confirmed, YES it doesn't the module which you mentioned.
