Etherchannel issue
Thameem1981
Community Member
Hello all,
I am trying to form EtherChannel just for testing in Packet tracer and not getting the desired results. When I try to form LACP active on both ends one of the Port goes to I-Standalone mode, not sure what mistake I am doing. Someone can have a look at the config and explain the issue here.
Problem between CSW2>DSW1>Port22 and PO2
CSW1:
interface GigabitEthernet1/0/22
switchport mode trunk
channel-group 2 mode active
interface GigabitEthernet1/0/23
channel-group 1 mode active
interface GigabitEthernet1/0/24
CSW2:
DSW1:
Etherchannel summary:
CSW1:
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gig1/0/23(P) Gig1/0/24(P)
2 Po2(SU) LACP Gig1/0/22(P)
CSW1#
CSW2:
2 Po2(SD) LACP Gig1/0/22(I)
CSW2#
DSW:
2 Po2(SU) LACP Gig1/0/23(P) Gig1/0/24(I)
DSW1#
6 Replies 6
It could be stuck as it doesn't seem to recognize LACP messages on the port. I would verify your configs and run a shut/no shut on the ports or even restart the devices.
Make sure you verify connections as well. i.e. the correct ports are plugged in/configured.
-David
M02@rt37
Hello @Thameem1981
The main issue lies in the mismatch of channel-group assignments and potentially misaligned configurations between CSW2 and DSW1. Align the channel-group configurations on both ends and ensure all interfaces in the EtherChannel have identical settings.
First create Po interfaces on each side, and add interfaces on that Port-Channel.
Once corrected, the EtherChannel should form correctly without any ports in I-Standalone mode.
Best regards
@Thameem1981
Dont add the config to the interface. Just add the interface to the port-channel and then add the config to the port-channel
Int po X
Dont worry' save lab close it and open again and issue will solved.
MHM
Martin L
PT is just a simulator; not real thing; some things may not work or work as real IOS does;
you can attach PT file here but it must be in zip format
Regards, ML
**Please Rate All Helpful Responses **
Thameem1981
Community Member
Dear's
Thank you for all of your responses, I tried all the possible ways to make it work but still is not working, attached the packet tracer file for your reference. I dont know understand I just did what said that I configure PO's first then for the interfaces but still they are not forming. Any help would be appreciated.
Thank you all..
