Etherchannel Load balancing
xcz504d1114
Level 7
Level 7
If the load balancing is set to src-dst-ip, will a layer 2 switch forward based on that information? Particularly talking about a 6500, with trunk interfaces, since those packets never go to the layer 3 engine, will the load-balancing work as intended?
Craig
Giuseppe Larosa
Hello Craig,
yes it will work as intended as it is still a multilayer switch specially for a C6500
Hope to help
Giuseppe
Giuseppe Larosa
Hello Craig,
Hope to help
Giuseppe
Reza Sharifi
Correct, it will load balance each source to a separate link.  For example:  If you have 2 PCs connected to tow different ports on 6500-A and the 6500-A has 2 uplinks to 2 different switches (6500-B and C) using an Etherchannael, on the output interface 6500-A you will see packet from one PC on one interfcae and the other PC on a different interface.
