Showing results forĀ
Search instead forĀ
Did you mean:Ā
Etherchannel load sharing algorithm
sridhar ch
Level 4
Level 4
I got 2*4500x switches connected B2B on L2 & L3 port channels. L3 for OSPF, L2 for VLAN's.
I have a requirement to setup one more L2 PO between 4500x and checkpoint FW. Current algorithm is src-dst-ip. I want both the ports in the new PO to share traffic. what would be the algorithm? if i change the algorith, will there be any impact to exisitnng PO's?
4500x switch supports below
dst-ip Dst IP Addr
dst-mac Dst Mac Addr
dst-port Dst TCP/UDP Port
src-dst-ip Src XOR Dst IP Addr
src-dst-mac Src XOR Dst Mac Addr
src-dst-port Src XOR Dst TCP/UDP Port
src-ip Src IP Addr
src-mac Src Mac Addr
src-port Src TCP/UDP Port
Sridhar
7 Replies 7
we can recommend one for you but there is from my view one point I read in cisco doc. you need to match the load balance in both side.
so select the load balance hash support from both SW and FW
thx for the quick response. on checkpoint end, we are planning to use Layer3+4 as shown below.
 Layer 2 information (XOR of hardware MAC addresses), or Layer 3+4 information (IP addresses and Ports)
since there are two PO
L2 PO must use L2 and cisco side have these options
L3 PO FW use L3+L4 cisco side have these options
dst-ip Dst IP Addr
src-ip Src IP Addr
It also helps to know what kind of traffic is traversing the link to know what load balancing method to use. If the link is going to a file server then using the destination IP/MAC address isn't going to work well since those will be the same. I am not certain if the load balancing will use the destination IP address for the load balancing or it would use the next hop IP it is routed traffic transiting the link. The distribution will never be totally even, but you may have to different load balancing methods and see which one gives the best distribution.
Hi Elliot,
the traffic that will cross the new PO is internet (teams, O365 etc). both core switches and FW's are in the same VLAN with FW inside connected to core as shown below. all 4 are running OSPF.
Joseph W. Doherty
Often src-dst-ip is a good all around choice.
Understand your LB choice only impacts egress traffic.  For ingress, you need to set the other side's device.
"if i change the algorith, will there be any impact to exisitnng PO's?"
Depends on the attributes of the traffic on every port-channel. Another reason why src-dst-IP is a often a good choice.
configured PO between 4500x and checkpoint with src-dst-ip on cisco and layer3+4 on the other end. all looks good.
