Etherchannel on Cisco 2960S
broow
what is the maximum number of etherchannels i can build on a Cisco 2960S stack.  We hoping  to connected 15 servers using 2 port channels between two stacked 2960 for redunancey.  So what is the max number of channels can i build using the 2960S?  Is the max 6 or is it more?
2 Accepted Solutions
Bilal Nawaz
Hello - the cisco document states that:
EtherChannel Configuration Guidelines
Note Stacking is supported only on Catalyst 2960-S switches running the LAN base image.
If improperly configured, some EtherChannel ports are automatically  disabled to avoid network loops and other problems. Follow these  guidelines to avoid configuration problems:
Do not try to configure more than 6 EtherChannels on the switch stack.
- Configure a PAgP EtherChannel with up to eight Ethernet ports of the same type.
- Configure  a LACP EtherChannel with up to16 Ethernet ports of the  same type. Up to  eight ports can be active, and up to eight ports can  be in standby  mode.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/configuration/guide/swethchl.html#wp1275881
Maximum I have ever encountered has been 6.
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Steve Fuller
Level 9
Level 9
As per the EtherChannel Configuration Guidelines in the Configuring EtherChannels and Link-State Tracking section of the software configuration guide the limit is six:
  • Do not try to configure more than 6 EtherChannels on the switch stack.
Bilal Nawaz
Hope this helps
Steve Fuller
Level 9
Level 9
thanks
broow
thanks
