EtherChannel on Router with 3650 Switch
SS-Shine
PaI am using Packet Tracer to create a Lab.
On NY-R1 I am not able to create the port-channel 1.10 sub-interface.  Does Packet Tracer allow me to create ether-channel sub-interface?
NY-R1(config)#interface port-channel 1.10
% Invalid input detected at '^' marker.
Trying to create 4 sub-interface on router for 4 VLANs.
Sunny
10 Replies 10
Can you provide the output of the following command:
interface port-channel ?
To see what your options are. I believe you will need to create the sub interfaces and make them a part of the channel group.
Packet tracer may also not support that function.
-David
Joseph W. Doherty
Cannot say with 100% certainly, why PT doesn't accept that configuration option, but can say with 100% certainly, PT, generally, doesn't support all the features the real hardware/software would.  So, beyond the most basic configuration options, they are very often not provided.  Also, BTW, whatever features PT does provide may not work as they do on the real platform.
SS-Shine
NY-R1#sh int port-channel 1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0006.2a9d.3b2c (bia 0006.2a9d.3b2c)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Half-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Members in this channel: Gig0/0 Gig0/1
Last input 00:00:08, output 00:00:05, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
956 packets input, 193351 bytes, 0 no buffer
Received 956 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 watchdog, 0 multicast, 0 pause input
2357 packets output, 263570 bytes, 0 underruns
0 output errors, 0 collisions, 10 interface resets
0 lost carrier, 0 no carrier
NY-R1#sh run
Building configuration...
Current configuration : 799 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname NY-R1
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX152400OC-
spanning-tree mode pvst
interface Port-channel1
no ip address
interface GigabitEthernet0/0
no ip address
channel-group 1
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
channel-group 1
duplex auto
speed auto
interface Serial0/0/0
ip address 172.16.1.2 255.255.255.0
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
NY-R1#
NY-R1#
NY-R1#
NY-R1#
NY-R1#sh ip int bri
Port-channel1 unassigned YES unset up up
GigabitEthernet0/0 unassigned YES unset up up
GigabitEthernet0/1 unassigned YES unset up up
Serial0/0/0 172.16.1.2 YES manual up up
Serial0/0/1 unassigned YES unset administratively down down
Vlan1 unassigned YES unset administratively down down
RedNectar
Hi @SS-Shine ,
Keep in mind that it is probably 10 years since I configured one of these, so I may have forgotten things. But in the config you showed below, I see:
no ip address
If you want to use sub-interfaces, I would have EXPECTED to see:
no switchport
no ip address
On the assumption that the default configuration for a port-channel is switchport, not a routed interface.
And as a bonus - let me give you some tips for posting to the forum (especially about posting console output)
RedNectar's Forum Tips:
    • When pasting code/CLI output, expand the top menu by clicking the ellipsis RedNectar_0-1707169195575.png
      This will give you access to the paragraph formatting drop down
      After clicking Preformatted, click HTML and paste your content between the <pre> </pre> tags.  This will stop multiple spaces being squeezed into a single space.RedNectar_1-1707177831922.png
    • When you add pictures, add your pictures inline - i.e. PASTE your picture right where you want it.  If it is a screenshot, you'll probably then want to click on the image and make the image large - like this.
This means you pictures are actually SEEN (a) in the email that gets sent to subscribers and (b) anyone who looks at this post in the future. Adding pictures as attachments... puts your submission into the TL;DR category.
RedNectar aka Chris Welsh.
Hello Chris,
Thanks for the Tip.  I am configuring this in Packet Tracer 9 and it is on router 2901.  I do not have option to for no switch port.  Also, I need the router port as sub-interface so I can tag my vlans.
When I try interface port-channel 1.100 I receive "invalid input detected at as below
Does packet Tracer allow to create port channel sub-interface?
Sunny
Hi Sunny ,
Try this:
no switchport
exit
interface Port-channel 1.10
and see if the error still occurs.
The problem is that Cisco devices need to know if a port is a traditional router port (where you assign IPs to the interface/sub-interface itself) or a "switch" port (where you assign IPs to a VLAN interface, then enable the VLANs on particular "switchports")
By default, on a router, all interfaces are assumed to be router ports. Should you want the port to be used as a "switchport" you need to configure the switchport command on the interface.
By default, on a switch (your case) all interfaces are assumed to be "switchports". Should you want the port to be used as a "router port you need to configure the no switchport command on the interface.
Again I'm digging deep into my memory for this. Spent the past 10 years almost exclusively with ACI.
Thanks for the response and tip, but I try on R1 - and did not work
NY-SW1#config t
Enter configuration commands, one per line. End with CNTL/Z.
NY-SW1(config)#int
NY-SW1(config)#interface por
NY-SW1(config)#interface port-channel 1
NY-SW1(config-if)#no swit
NY-SW1(config-if)#no switchport
Command rejected: Not a convertible port.
Ah, version 9.  Last, time I recently looked (within the last couple of weeks), I recall version 8 was still the recommended version, so version 9 is still, perhaps, considered beta.  If so, possibly providing this feature is intended, but possibly just not working yet.  Or, as both @David Ruess and I have both suggested, missing features isn't uncommon within PT.
As to @RedNectar suggestion looking to insure port is not in switchport mode, that should be a non issue on a router's built-in (L3) ports.  I recall (?) it was applicable if using a router's L3 switch module's ports.  However, I wouldn't suspect PT to (possibly ever) simulate them.
A CML router would likely support the configuration option(s) you're trying to configure.
Oh, forgot to mention, I believe Cisco now allows for a free 5 node version of CML, plus I recall their on-line version is free too, although it has other usage considerations beyond node count.
@Joseph W. Doherty ,
Thanks for doing the legwork to (in)validate my attempt.
