Etherchannel on Stacked 3750 Switch
cisco
       Can etherchannel (using two uplinks) be configured between a single 2960 and a stacked 3750 switch.
Connectivity will be like this
one cable Switch_2960_A going to  Switch_3750_1 of the stack and second cable from same Switch_2960_A to Switch_3750_2 .
regards
Neo
Shashank Singh
Hi Neo,
Stack is a single logical switch and hence etherchannel between different stack switches and 2960 as mentioned is very much possible. No special configuration is required to achieve this. For eg:
2960 switch
int gi0/1
channel-group 1 mode on
exit
int gi0/2
3750 stack
int gi1/0/1  ------> on switch 1
exit
int gi2/0/1  -----> on switch 2
Cheers,
Shashank
Please rate if you found the content useful
Shashank Singh
Hi Neo,
2960 switch
int gi0/1
exit
int gi0/2
3750 stack
exit
Cheers,
Shashank
