Etherchannel per port bandwidth
sqambera
I have done Etherchannel configuration on one of my switch. The load balancing is enabled as src-dst-ip. My question is that what happens if one of the port that is being utilized for a specific source-destination ip reaches its maximum capacity? Will there be conjustion or another port of the etherchannel will be brought to utilization for the same couple?
Reza Sharifi
Correct, if it is coming from the same source and the link is over utilized, then there will be packet drops and the traffic will not get shifted to another physical port.  Remember, when you create a  Portchannel, you just  add more pipes, but don't increase the bandwidth of the physical interface.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
My question is that what happens if one of the port that is being utilized for a specific source-destination ip reaches its maximum capacity? Will there be conjustion (yes) or another port of the etherchannel will be brought to utilization for the same couple (no)?
If this situation routinely arises, you might want to see if another hashing algorithm works better in your situation.
