Switch L3 not routing properly
eltote1982
Hi all,
I am having some routing issues with a L3 switch.
Firstly, I am following this document in order to complete my configuration, but it is working quite odd...
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
Well, I have attached a diagram to help with my explanation.
I have a Router to connect "out-of-site LAN" networks and 2 L3 switches to manage Users vlans. Everything seems to be working fine, I can ping to the switches from any host in the network (including other sites) with the default route to the router, but I cannot connect through ssh to the switches unless I add the route in bold I copied below, which it is quite strange, since it should be included in the default one. I want to "delegate" all routing process to the router.
NOTE: I hace in place 3 different HSRP groups:
128: This group manages the internal GW IP which it is the router by default. In case the router goes down, one switch will became the internal GW and I will need to change the routes manually to be able to access to other Internal Networks (through vlan 248)
129: This group is the GW to Users vlan. Basically, the router will forward to the switches that traffic.
248: This HSRP is to connect with other internal sites. The router will be the default one, but in case it goes down a switch will became active (same as 128 group)
Here I also copy the "interesting" configuration of the devices (ask me if you need something more)
SWITCH (the other switch is simillar just changing IPs and HSRP priority)
ip routing
interface GigabitEthernet0/9
description ** Router LAN Conection **
switchport mode trunk
speed 1000
duplex full
no cdp enable
interface GigabitEthernet0/23
description ** Lanlink **
switchport trunk allowed vlan 248
speed 100
duplex full
no cdp enable
interface Vlan128
description ** VLAN 128: DR LAN MNG **
ip address 10.105.128.8 255.255.255.0
no ip redirects
standby 128 ip 192.168.128.1 --> HSRP switches and router
standby 128 priority 130
standby 129 ip 192.168.128.10 --> HSRP between switches
standby 129 priority 150
interface Vlan248
description ** VLAN INTERNAL LINK **
ip address 192.168.248.52 255.255.255.0
no ip redirects
standby 248 ip 10.105.92.50 --> HSRP switches and router
standby 248 priority 130
ip route 0.0.0.0 0.0.0.0 192.168.128.1
ip route 192.168.12.0 255.255.252.0 192.168.128.1 name IT_USERS
ROUTER
interface GigabitEthernet0/0
no ip address
no ip route-cache
duplex full
speed 1000
interface GigabitEthernet0/0.128
description ** VLAN HQM LAN MANAGEMENT **
encapsulation dot1Q 128
ip address 192.168.128.5 255.255.255.0
no ip redirects
ip virtual-reassembly in
no ip route-cache
standby 128 priority 150
no cdp enable
interface GigabitEthernet0/0.248
encapsulation dot1Q 248
ip address 192.168.248.51 255.255.255.0
no ip redirects
no ip route-cache
standby 192 ip 192.168.248.50
standby 192 priority 150
no cdp enable
ip route 0.0.0.0 0.0.0.0 <GW>
ip route 192.168.0.0 255.255.128.0 10.105.92.1
ip route 192.168.160.0 255.255.240.0 192.168.128.10 name USERS
Does anyone have an idea what I am doing wrong? For me it doesn have any sense but obviously I must be wrong
Thanks in advance,
Jose
eltote1982
Hi again,
I just configured the syslog to be saved in a server on 192.168.10.0/24 network and it is working perfectly :$ seems like it is not working with TCP traffic only (https server doesn work either)
Jose
Hi Jose,
there seem to be some misconfiguations, for example in VLAN 128, the VIP doesn't match the SVI's IP-Address network.
#show ip interface brief vlan128
Interface                  IP-Address      OK? Method Status                Protocol
Vlan128                    10.105.128.8    YES manual up                    up
#show standby vlan 128
Vlan128 - Group 128
State is Init (virtual IP in wrong subnet)
Virtual IP address is 192.168.128.1 (wrong subnet for this interface)
Active virtual MAC address is 0000.0c07.ac80
Local virtual MAC address is 0000.0c07.ac80 (v1 default)
Hello time 3 sec, hold time 10 sec
Preemption disabled
Active router is 192.168.128.5, priority 150 (expires in 7.116 sec)
Standby router is unknown
Priority 130 (configured 130)
Group name is "hsrp-Vl128-128" (default)
With that configuration, the Next-Hop-IP of your static routes won't be reachable:
#show ip route 192.168.128.1
% Network not in table
By the way: The standby groups in VLAN 248 (248) and Gi0/0.248 (192) do not match, so both will declare themselves as active.
Hope that helps
Best regards
Rolf
Hi Rolf,
First of all, thanks for your answer and sorry for the mistake, I copied from my text config file, but it is ok in the running configuration:
SWSB-HQM-LAN01#sh ip interface brief vlan128
Vlan128                192.168.128.8    YES NVRAM  up                    up
SWSB-HQM-LAN01#sh standby vlan128
Vlan128 - Group 128
  State is Standby
    1 state change, last state change 05:58:03
    Next hello sent in 1.008 secs
  Authentication MD5, key-string
  Preemption enabled
  Active router is 192.168.128.5, priority 150 (expires in 11.328 sec)
  Standby router is local
Vlan128 - Group 129
  State is Active
    2 state changes, last state change 05:58:03
  Virtual IP address is 192.168.128.10
  Active virtual MAC address is 0000.0c07.ac81
    Local virtual MAC address is 0000.0c07.ac81 (v1 default)
    Next hello sent in 0.992 secs
  Preemption enabled
  Active router is local
  Standby router is unknown --> (the other switch is not installed yet)
  Priority 150 (configured 150)
  Group name is "hsrp-Vl128-129" (default)
SWSB-HQM-LAN01#sh standby vlan248
Vlan248 - Group 192
  State is Standby
    1 state change, last state change 05:58:55
  Virtual IP address is 192.168.248.50
  Active virtual MAC address is 0000.0c07.acc0
    Local virtual MAC address is 0000.0c07.acc0 (v1 default)
    Next hello sent in 2.464 secs
  Preemption enabled
  Active router is 192.168.248.51, priority 150 (expires in 9.952 sec)
  Group name is "hsrp-Vl248-192" (default)
NOTE: I use authentication MD5 for HSRP, but I didn copy that part of the configuration.
SWSB-HQM-LAN01#sh ip route 192.168.128.1
Routing entry for 192.168.128.0/24
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Routing Descriptor Blocks:
  * directly connected, via Vlan128
      Route metric is 0, traffic share count is 1
Jose
eltote1982
Sorry, I have found the problem, the problem was not  on the switch nor on the router, it was a routing problem on the rest of  the network devices on the internal network...
Thanks for your help and sorry again...
Jose
