Etherchannel port suspended error
prashantrecon
Hi All
Etherchannel for gi1/32 and gi1/0/39 is working fine
But etherchannel for gi1/33 and gi1/0/40 is not up
On site1                      on site2
gi1/32(ISP 1)                     gi1/0/39(ISP 1)
gi1/33(ISP2)                        gi1/0/40(ISP2)
gi1/32 and gi1/0/39  on site1 and site2 bundled with etherchannel
gi1/33 and gi1/0/40 on site1 and site 2 are bundled withe etherchannel
Interface status
Gi1/0/39                     connected    routed     a-full  a-100 10/100/1000BaseTX
Gi1/0/40                     suspended    routed       full    100 10/100/1000BaseTX
Gi1/32       "tata point to poi connected    routed     a-full  a-100 10/100/1000BaseT
Gi1/33                          notconnect   routed     full    100 10/100/1000BaseT
Note -Duplex seetings on gi1/33  and gi1/0/40 are same
7 Replies 7
Ganesh Hariharan
Hello ,
There is one important rule when configuring etherchannels: All interfaces in the etherchannel need the same speed and duplex settings, trunking encapsulation (dot1q/isl) or the same access VLAN in case of an access port, same STP cost and last but not least: no etherchannel port can be configured in a monitor session (SPAN port).
If any of the above criteria fails then port can comedown in suspended state.
Hope it Helps !!
Ganeshh Iyer
Rate if it Helps...
Giuseppe Larosa
Hello Prashant,
as noted by Ganeshh the member ports need to have identical configuration in terms of speed and duplex
From the show command you have reported it looks like that ports connected to ISP1 are in auto mode auto 100 auto full, and ports connected to ISP2 are configured for 100 Mbps full duplex manually.
The etherchannel code is likely suspending the second port for this reason
You may need to interact with ISP2 tech stuff to achieve a compatible configuration with the first link.
Hope to help
Giuseppe
Isp 1 has set as below followig parameters
Auto-Negotiation
Flow Control
Speed and Duplex           100Mbps, Full Duplex
Auto-Negotiation Status               Complete
On my side  for isp1 i have done no seetings The interface status  at both sides is as
Full-duplex, 100Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is off
  Clock mode is auto
Etherchaanel is working fine for this interface.
For isp2 following parameters
Speed : 100Mb
Duplex : full
Negotiation : off
On my side for isp2 I have set as
Speed : 100Mb
Duplex : full   on both inerface
But etherchannel is displaying as suspended
Hello Prashant,
Can you please post the show etherchannel detail output from the switch that reports the suspended port? Thank you!
Best regards,
Peter
35   Po35(RU)        LACP      Gi1/0/39(P) Gi1/0/40(s)
From your initial post, Gi1/0/39 connects to ISP1 & Gi1/0/40 connects to ISP2 (both at Site2).
If that's the case, you won't be able to configure port channel between these interfaces.
For a port-channel to come up, the remote side of the member ports should also be on the same switch / virtual switch.
Shijo George
Please find attachement
