EtherChannel problem, 3750X <--> 6509E
fearless.rabbit
Hello guys,
I desperately need help configuring EtherChannel between 3750-X cross-stack and 6509E switch. I use two ports on 3750s, and two ports on 6509. I just need it as a trunk. For some elusive reason one port on 3750 keeps being err-disabled, and one on 6509 notconnected.
Here is what I did so far.
3750
interface GigabitEthernet1/0/22
description ***VSS-RNOC-link***
switchport trunk allowed vlan 2
speed 1000
duplex full
no vtp
channel-group 15 mode on
end
interface GigabitEthernet2/0/22
speed 1000
duplex full
no vtp
end
interface Port-channel15
end
6509
interface GigabitEthernet2/1/28
description ***Dom_Vojske_Failover_link***
switchport
switchport mode trunk
speed 1000
duplex full
channel-group 220 mode on
end
interface GigabitEthernet2/1/29
switchport
speed 1000
duplex full
end
interface Port-channel220
switchport
no vtp
end
These bastards give me headaches:
GigabitEthernet1/0/22 is down, line protocol is down (err-disabled)
GigabitEthernet2/1/29 is down, line protocol is down (notconnect)
I tried shuting them down, then no shuting them again. Didnt help.
Any ideas?
Peter Paluch
Hello Milos,
It is a blind shot but I am increasingly getting the feeling that the ports you are configuring for the EtherChannel are not the true ports that interconnect your 3750 and 6509 together.
Note the output you've provided:
show etherchannel summary on 3750:
15     Po15(SD)        LACP      Gi1/0/22(I) Gi2/0/22(D)
The gi1/0/22 is identified as an (I)ndividual port - that means that the opposite device is not speaking LACP to it so it cannot negotiate about even becoming an EtherChannel member link. The gi2/0/22 is (D)own meaning that the opposite port is shutdown or not even connected.
Can you verify using CDP (show cdp neighbor) or LLDP (show lldp neighbor) that the ports you're configuring are indeed the ports that connect your 3750 and 6509 together?
And of course verify that none of the ports you're configuring on either switch aren't put into err-disabled or shutdown state.
Best regards,
Peter
11 Replies 11
Peter Paluch
Hi Milos,
Can you issue the show interfaces status err-disabled and post the output here after the ports on the 3750 get err-disabled? This will reveal the reason why they are being err-disabled.
Very often, ports like these get err-disabled because of EtherChannel Misconfig Guard that gets tripped when the opposite device has not its ports bundled into an EtherChannel yet. However, the configuration of your 6509 seems to be okay for the time being. Are you sure you are bundling the correct ports?
One recommendation - do not use channel-group mode on unless absolutely necessary. Use LACP to negotiate the EtherChannel, i.e. I strongly suggest removing the EtherChannel configuration altogether and instead, reconfigure the EtherChannel on both devices using channel-group mode active. This will both avoid your ports being put into err-disabled state because of problems with EtherChannel, and allow these devices to actually negotiate whether the ports can be bundled.
Best regards,
Peter
Dear Peter,
Thank you very much for such a quick reply
I have put all interfaces into active mode instead of on, and now Port-channel interfaces are err-disabled as well.
Here is show interfaces status err-disabled
DV-CORE#show interfaces status err-disabled
Port      Name               Status       Reason               Err-disabled Vlans
Gi1/0/22  ***VSS-RNOC-link** err-disabled channel-misconfig (STP)
Gi2/0/21                     err-disabled channel-misconfig (STP)
Po15      ***VSS-RNOC-link** err-disabled channel-misconfig (STP)
DV-CORE#
Wow, wow wow.. is STP taking them down?
Hello Milos,
Suggestion - these kinds of errors usually occur when you change the mode of the physical interfaces (e.g. from on to active) but do not delete the logical Port-channel interfaces. It appears that the Port-channel interface is internally created with a notion of the signalling protocol being used, and if the protocol is changed on the physical interface, the internal Port-channel setting is mismatched, and as a result, the ports are being put into err-disabled state.
My suggestion:
  1. Remove the channel-group commands from all affected physical interfaces. In other words, tear down the EtherChannel between your 3750 and 6509 completely.
  2. Shut down the physical ports if not shut down already. This will clear the err-disabled state.
  3. Remove the Port-channel interfaces using no interface port-channel X if they still exist. This is a very important step.
  4. Now, start the physical interfaces again using no shutdown and bundle them again using channel-group mode active. Do not manually create the Port-channel interfaces - they will be created automatically.
Please give this a try and let us know how it worked. Thank you!
Best regards,
Peter
Ok, I did as you said - excluded ports from EtherChannel, shut them down, and deleted the previous Port-channel interfaces on both 3750 and 6509. I have let new Port-channel interfaces be created automatically, unlike me creating them manually before
Now only two interface are up. Other two physical interfaces and both Port-channel interfaces are down, line protocol is down (notconnect).
Maybe I should try having same Port-channel ID on both switches (it is 15 on 3750 and 220 on 6509)? I believe this is just locally significant, but maybe is worth a try?
P.S. I have put them all in active mode.
maybe its removed but i dont see "switchport mode trunk" configured on the 3750 port-channel and interfaces.
i have configured the 3750X and the 65009-E  w/ channels like this, works like a charm:
3750X
interface Port-channel25
interface GigabitEthernet1/1/1
channel-protocol lacp
channel-group 25 mode active
interface GigabitEthernet1/1/3
6509-E
switchport
mls qos trust dscp
interface GigabitEthernet7/10
switchport
interface GigabitEthernet8/10
switchport
Defaulted them all again, recreated Port-channels.. it still wont come up It`s like it ignores second interface altogether.
sh etherchannel 15 detail
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
Ports in the group:
Port: Gi1/0/22
Port state    = Up Sngl-port-Bndl Mstr Not-in-Bndl
Channel group = 15          Mode = Active          Gcchange = -
Port-channel  = null        GC   =   -             Pseudo port-channel = Po15
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi1/0/22  SA      indep     32768         0xF       0xF     0x117       0x7D
Age of the port in the current state: 0d:00h:05m:03s
Port: Gi2/0/22
Port state    = Down Not-in-Bndl
Local information:
Gi2/0/22  SA      down      32768         0xF       0x0     0x217       0x45
Age of the port in the current state: 0d:00h:06m:23s
Port-channels in the group:
Port-channel: Po15    (Primary Aggregator)
Age of the Port-channel   = 0d:00h:06m:38s
Logical slot/port   = 10/15          Number of ports = 0
HotStandBy port = null
Port state          = Port-channel Ag-Not-Inuse
Protocol            =   LACP
Port security       = Disabled
DV-CORE#sh int g1/0/22 status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi1/0/22  ***VSS-RNOC-link** connected    trunk        full   1000 10/100/1000BaseTX
DV-CORE#sh int g2/0/22 status
Gi2/0/22  ***VSS-RNOC-link** notconnect   1            full   1000 10/100/1000BaseTX
3750 config:
end
speed 1000
duplex full
no vtp
channel-group 15 mode active
end
speed 1000
duplex full
no vtp
end
6509 config:
switchport
end
switchport
speed 1000
duplex full
channel-group 220 mode active
end
switchport
speed 1000
duplex full
end
Hello Milos,
The Port-channel number is irrelevant - it can safely be different between different switches.
Would you mind posting the output of the following commands on the 3750?
  • show cdp neighbor
  • show ether sum
  • show ether 25 detail
  • show int gi1/1/1 status
  • show int gi1/1/3 status
Thank you!
Best regards,
Peter
Hello.
Error disable reason clearly states:
Spanning-tree inconsistent !!! Check the physical connections, because either your 3750 stack or your VSS chassis
is broken into two. Or you simple have interfaces going to another switch that we don't have in the picture.
Regards.
Wilson B.
My VSS is in fact two 6509E chassis. I am connecting 3750 to one of them. Could this somehow be the issue?
Peter Paluch
Hello Milos,
Best regards,
Peter
Well Peter, your blind hit is more accurate than 48 hours of my "troubleshooting". I have been configuring wrong VSS chassis as along! God knows what I f*cked up on the other side
You learn as long as you live I guess. Thank you all immensly nonetheless guys. I would take me at least another 48 hours until I turned my eye on actual cabling
