etherchannel problem
jean tang
Visitor
guys, I have some problems with etherchannel configuration
3 switches(3550/3560): SW1-------SW2--------SW3 (both connecting with each other with two ports, SW3 connects with SW1 also having two ports)
SW1/SW2/SW3: inter range f0/19 -20
                              channel-group 1 mode on
                         inter range f0/21 -22
I tried on/lacp/pagp mode, but always four ports go down, suspended state (speed,dupluex,native vlan,all same)
It really troubles me
Can I use the same port-channel name 1 for one group in three switches?
Is there too many ports in one group?
any loop occurs?
what am i doing wrong?
thanks a lot
rtjensen4
Level 8
Level 8
If I understand correctly, you're trying to use group 1 to connect an etherchannel to one switch, and use group 1 to connect a 2nd etherchannel to another switch?
The group number is local to the switch only. But you can't use the same group for different ether channels, the switch will think they're in the same channel.
Switch 1 could have:
Group 1 connecting it to SW2
Group 2 connecting it to SW3
Switch2:
Group 1 Connecting to SW3
Group 2 Connecting to SW1
Switch3:
Group 1 Connecting to SW2
vdadlaney
Level 5
Level 5
Hi Jean,
I will try and attempt an answer to your question. If i understand your scenario correctly it seems you have 3 switches in a the following setup (Hope the ascii comes out correctly)
SW1----------SW2
       SW3
If that is so than you can use channel-group 1 to form the etherchannel between SW1 and SW2. however on SW1 you have to use a different channel-group. If you look at show etherchannel summary with the way you have it configured now you would see that all the ports F0/19 - F0/22 are configured under the same etherchannel which basically means they are going to the same device and this is not correct because you have 2 ports going to SW2 and 2 ports going to SW3. HTH
jean tang
Visitor
rtjensen4 and vdadlaney, thank you for your help
sorry...my english really needs work
actually, the topology is....
SW1----------SW2
       SW3
but I understand my mistake now~~~~
best regards
