Etherchannel sequence
weilliu
Community Member
Hi Experts,
I would like to know the Etherchannel sequence.
If I have 2 ports in EtherChannel, for example, port 1 and port 2.  Source and destination mac is my load balance method.  I would like to know when the first packet goes to the Etherchannel, which port that the 1st packet will go, port 1 or port 2.
I am sure it would only go by one port for each session, and I wonder which port it would take when the first packer arrives.
Thank you,
Aries
6 Replies 6
chandra_rc16
Level 7
Level 7
Hi Aries,
Nice question.
I just now did three experiments on this and at the three times... the first frame has passed throught the port with the lowest number.
For ex:
My first port-channel has Fa0/1 and Fa0/2 ,,, the first frame passed through Fa0/2.
My second port channel ex: There were two ports already in channel they were Fa0/14,Fa0/15... fa0/15 was first added to the channel... but the frame chose Fa0/14 for the first time.
My third ex: There were Fa0/15 and Fa0/14 channels... then after i added Fa0/1... the first frame chose Fa0/1.
Chandu
Regards, Chandu
Furose M
Level 8
Level 8
which platform is it?
its not like the first packet goes here and the 2nd packet goes there.. it calculates a hash value based on the load-balance method and based on the hash value outcome, it chooses the egress interface.
Hi Ali,
I've checked it on 2960 switches.
Chandu
Regards, Chandu
I think we should be able to find the egress interface for a specific flow (src mac / dst mac) using this command in 3750 (i belive same applies to 2960 - havent tested).
test etherchannel load-balance interface port-channel
Ali,
I've tested with the load balance method of src-dst-mac.
Chandu
Regards, Chandu
Hi Ali & Chandu,
I was talking about 3750 actually.  We can test it and find out which port it is going, that is no problem.  However, I am just thinking why it takes this port as first path.  I am not sure if it uses hash algorithm to do so.  I keep searching.
regards,
Aries
