Etherchannel WLC & 4507
anthony.dyne
Seeking for Etherchannel configuration help between WLC 5508 and 4507.
thanks
Anthony
2 Accepted Solutions
Hi Anthony,
Follow this guide:
http://www.cisco.com/en/US/docs/wireless/controller/7.0MR1/configuration/guide/cg_ports_interfaces.html#wp1277659
I am giving you link because there are alot considerations when you are making the config and they are explained in this document e.g.  - When you enable LAG or make any changes to the LAG configuration, you must immediately reboot the controller
Best regards,
Alex
Hi Anthony,
Please see the example config on 4507 from best practice and currently I am using it.
interface Port-channel1
switchport
switchport trunk native vlan 50
switchport mode trunk
interface GigabitEthernet3/31
description Connected to Blade link 4
channel-group 1 mode on
Please rate the helpfull posts.
Naidu.
Hi Anthony,
Follow this guide:
Best regards,
Alex
Hi Anthony,
switchport
Naidu.
