Etherchannel
vidarellingsen
Community Member
Hey,
whats the difference between PagP, LCPD and just "mode on" on etherchannels. Is there any benefits to use one over the other?
Vidar
Marwan ALshawi
The Cisco proprietary negotiation for EtherChannel is known as Port Aggregation
Protocol (PAgP). PAgP is enabled by enabling a channel in either the 'auto' or
'desirable' mode. When an interface runs PAgP in auto mode it will listen for
PAgP packets received on the interface and agree to negotiate once these
packets are received. An interface in auto mode will not initiate negotiation
through PAgP. When an interface runs in desirable mode it will initiation PAgP
negotiation.
The open standard for EtherChannel negotiation is Link Aggregation Control
Protocol (LACP), and is defined in IEEE 802.3ad.
To disable both PAgP and LACP, set the channel mode to 'on'
please, if helpful Rate
