etherchannel
carl_townshend
Hi all, when setting up etherchannel on switch, do I have to set the port vlan memberships, and trunks on the individual ports and also the port channel afterwards ? or do I just do it on the port channel ?
mahmoodmkl
Level 7
Level 7
If u enable it on the port channel interface it will be effected on the physical interfaces.
Mahmood
what do you mean here?
I can just do all the config on the port channel rather than individual interface ?
yes u can do the config on portchaneel and it will reflect on the physical interfaces.
Mahmood
