Etherchannel
cciepending
Community Member
Hi All
What is the real difference between L2 and L3 etherchannels?
Rahul Kachalia
Some are identical and some are different:
Operational:
- Common mechanic between L2 and L3 EtherChannel is link bundling technique - PAgP, LACP. They function independently in which mode the EtherChannel is deployed in.
Control-Plane:
- L2 EtherChannel - Certain protocols like STP operates on logical EtherChannel interface. However certain protocols like DTP, CDP, PAgP, LACP etc operates on each individual member-link of same EtherChannel. Some of these protocols operate in independent interface mode.
- L3 EtherChannel - All protocols like OSPF/EIGRP/PIM etc operates on logical Layer 3 EtherChannel. All L2 protocols like CDP for example operates on each individual L3 member-links
Forwarding-Plane:
Answer really depends. If the system is standalone L2/L3 system then common fwding mechanic.
But if system is in virtual-switch mode like VSS, then unique hw based traffic-engg to load-share traffic intelligently between two systems.
Refer to Chapter 2 for more details in following guide:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/Borderless_Campus_Network_1.0/Borderless_Campus_1.0_Design_Guide.pdf
thanks,
rahul.
cadet alain
The same difference there is between a L2 port and a L3 port.
Regards.
Alain.
Rahul Kachalia
Operational:
Control-Plane:
Forwarding-Plane:
thanks,
rahul.
