Floating Static Routes
yuchenglai
Level 5
Level 5
Hi all,
I have a question about floating static routes. On a broadcast media, if I have two floating static route, each with a different AD and each specifying a different next-hop ip address, recursing out to the same ethernet interface, how would the router know when not to insert the particular static route into the RIB when the remote next-hop ip address falls off of the network?  This is assuming that the outgoing ethernet interface is in the up/up status when this event happens.
David
Giuseppe Larosa
Hello David,
the use of static routes over shared media has been historically a problem in the past.
without a way to check the IP next-hop it would be used until the ARP entry expires in the ARP cache that is up to 4 hours with default timers!!!
Nowdays you can make use of IP SLA to verify that the IP next hop is really alive quickly
see the link below
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
depending on the IOS version of your device IP SLA or rtr responder can be configured
Hope to help
Giuseppe
Giuseppe Larosa
Hello David,
see the link below
Hope to help
Giuseppe
Thanks Giuseppe!
