etherchannel
Feker Miri
Community Member
I have a problem with etherchannel in WS-C3650 :
In my LAN network, I have two C3650 in stackwise mode for Core and three C3650 in stackwise mode for access modul, when I apply a etherchannel configuration I see this error :
Apr 27 12:32:04.014: %EC-5-L3DONTBNDL2: Gi1/1/1 suspended: LACP currently not enabled on the remote port.
*Apr 27 12:32:51.374: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/1, changed state to up
*Apr 27 12:32:57.076: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/1, changed state to up
*Apr 27 12:32:58.065: %LINK-3-UPDOWN: Interface Port-channel1, changed state to up
*Apr 27 12:32:59.065: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
This is a configuration Core Switch :
interface Port-channel1
switchport trunk native vlan 18
switchport mode trunk
interface GigabitEthernet1/1/1
description ## PO TO Grn_floor ##
channel-group 1 mode active
interface GigabitEthernet2/1/1
This is a configuration in access switch:
end
interface GigabitEthernet1/1/2
 all Switch have same IOS-XE :cat3k_caa-universalk9.SPA.03.06.04.E.152-2.E4.bin
Can you help me
6 Replies 6
What's the output for the "show etherchannel summary "  command?
if you see "Po1(SU)" in output, everything should be fine and just ignore the error message. Maybe it's related to negotiation between ports. Otherwise, please share the output of the above command.
Houtan
thx to your replay
no
this is a outpout for the " sh etherchannel summary"
SWSCF-ACC4-GF3650#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi1/1/1(P) Gi1/1/2(s)
This "Gi1/1/2(s)" shows the port  is suspended. The reason maybe incompatibility between speed, duplex, .... on the interfaces. Try "show int " in all members and check the interface configuration.
Houtan
this is "show interface G1/1/1 "
SWSCF-Core-GF3650#sh interfaces gigabitEthernet 1/1/1
GigabitEthernet1/1/1 is up, line protocol is down (suspended)
Hardware is Gigabit Ethernet, address is 00c8.8bcd.acb1 (bia 00c8.8bcd.acb1)
Description: ## PO TO Grn_floor ##
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
devils_advocate
Level 11
Level 11
Try a Shut and No Shut on each port and on the Port Channel interface.
If not, try a switch reboot.
The config looks ok.
i tried but is same pb
