We're trying to connect our Nexus 9372 to an IBM V9000.
We've got the QSFP cable connected, I would expect to at least see L1 connectivity but the port is showing as not connected.
Very simple config for now -
interface Ethernet1/49
description ***V9000 iSCSI Node 1***
switchport access vlan 161
Ethernet1/49 is down (Link not connected)
admin state is up, Dedicated Interface
Hardware: 10000/40000 Ethernet, address: 0078.8883.6bdc (bia 0078.8883.6bdc)
Description: ***V9000 iSCSI Node 1***
MTU 1500 bytes, BW 40000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is access
auto-duplex, auto-speed, media type is 40G
Beacon is turned off
Auto-Negotiation is turned on, FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
Last link flapped never
0 interface resets
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression packets
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
Are we missing something in the config?
Thanks.
