EtherChannel
ssnachy0
Community Member
I am doing a lab in GNS for EtherChannel facing issue.
below are thinks done with both switches..
1. port range f1/1 - 3
2. channel-group 1 mode on
3. switchport mode trunk
when doing :- show interface trunk its showing status not-trunking.
Jitendra Kumar
the issue is already resolved in the below discussion I think.
https://community.cisco.com/t5/small-business-switches/etherchannel/m-p/4620328#M25965
Jitendra
Jitendra
 Where this interface is connected to? Does the other side also is configured? Does the interface is UP?
Trunk state is a negociation result just like Port-Channel. You need to have both side up and running.
Georg Pauwen
which images are you using ? Since these are FastEthernet interfaces, my guess is you are using the Dynamips images ?
Post the full running configs (sh run) of both switches...
Jitendra Kumar
Jitendra
Jitendra
