Catalyst 1000 port interface mismatch
Support ACME
Dear ALL,
I 'm configuring the C1000-16T-2G-L, the interface should be 16 GigabitEthernet (1/0/1-1/0/16) and 2 fiber port(1/0/17-1/0/18), i plugged the 2 x GBIC to fiber port and use "show inventory" can see the two 2 x gbic(1/0/17-1/0/18), but i cant configure the 2 fiber port(1/0/17-1/0/18), anyone can help?
WAN_Switch_2#sh run
Building configuration...
Current configuration : 3034 bytes
! Last configuration change at 18:11:39 UTC Fri May 27 2022
version 15.2
no service pad
hostname WAN_Switch_2
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision c1000-16t-2g-l
system mtu routing 1500
vtp mode transparent
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 101
name WAN-Management
vlan 301,1000-1001
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
switchport trunk allowed vlan 301
switchport mode trunk
interface GigabitEthernet1/0/16
switchport access vlan 301
spanning-tree portfast edge
interface Vlan1
no ip address
ip http server
WAN_Switch_2#show inv
WAN_Switch_2#show inventory
NAME: "1", DESCR: "C1000-16T-2G-L"
PID: C1000-16T-2G-L , VID: V01 , SN: FOC2545Y2PQ
NAME: "GigabitEthernet1/0/17", DESCR: "1000BaseLX"
PID: 31A563 , VID: , SN: F2011000562
NAME: "GigabitEthernet1/0/18", DESCR: "1000BaseSX"
PID: GLC-SX-MMD , VID: V03 , SN: FNS25320920
Support@ACMEHK
reccon
Assuming your switch was "switch 1" in the stack (sh switch):
conf t
no switch 1 hstack-port 1 GigabitEthernet 1/0/17
no switch 1 hstack-port 2 GigabitEthernet 1/0/18
(switch needs a reboot for the changes to take effect)
7 Replies 7
Mark Elsen
         >....but i cant configure the 2 fiber port(1/0/17-1/0/18), anyone can help
                             What happens when you try that ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
i cant see the interface when i execute command " sh run ".
- Can you see them with command : show interface status
M.
       Beauty and terror
      Just keep going
       No feeling is final
the last port is 1/0/16.
reccon
Was this switch part of a stack?
Ports that are configured as stack ports don't show up in the config or in "sh int status"
show switch hstack-ports
Switch#show switch hstack-ports
Horizontal stack port status :
Gi Ports Stack Port Operational Status Next Reload Status Media Type
Gi1/0/17 1 Stack Port Stack Port Fiber
Gi1/0/18 2 Stack Port Stack Port Fiber
Yes, under the hstack-ports.
how to remove it?
reccon
conf t
