Etherchannel
sudeesh79
Level 3
Level 3
Hi all
Please tell me how many Etherchannel can I create in a 2960 Switch?
Sudeesh
I want to create 12 etherchannels, Is it possible by upgrading or something.
Sudeesh
Looks like etherchannel limitation is a feature of hardware. & in your case 2960 support only 6 etherchannels.
Model 2970 & higher support more no. of etherchannels.
Refer this link:
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094646.shtml#topic8a
keeleym
Level 9
Level 9
Hi Sudeesh
Please see the following link.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swethchl.html
On a 2960 switch, you can create up to 6 Etherchannels and each Etherchannel can contain up to 8 ports which would yeild up to 800mbps if the ports used were 100 mbps or up to 8gb if the ports used were 1gbps ports.
Best Regards,
Michael
