Ethernet card compatibility
srflanigan4234
Which WIC or NM Ethernet card is compatible with a 2620, (non XM)  router?  I have seen conflicting information on compatibility.  I am wanting to connect this router via an Ethernet Port with a non Cisco router that is connected to my ISP.
Thanks.
Reza Sharifi
You can use:
  • NM-4E—Four-port Ethernet or
  • NM-1E—One-port Ethernet
see table-2 in this link:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b89.html
