Ethernet Circuit Issue
jdavid6568
Community Member
I have a 150M point to point ethernet circuit connected via Single Mode Fiber from our 3560 switch to the another 3560 at a remote facility. I have configured both sides as routed ports on /30 connector. The remote switch interface is showing up/'up connected but the switch interface at the near end is showing down/down (not connected). Both sides are configured exactly the same and we have verified light from the carrier. We have also verified that the Tx and Rx are connected correctly. Any ideas on why the near side is not coming up?
nterface GigabitEthernet0/25
description cpeneams1 gi0/25
no switchport
ip address 172.26.1.37 255.255.255.252
GigabitEthernet0/25 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is e840.40e9.29c1 (bia e840.40e9.29c1)
  Description: cpeneams1 gi0/25
  Internet address is 172.26.1.37/30
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
interface GigabitEthernet0/25
description crlneams2 port gi0/25
no switchport
ip address 172.26.1.38 255.255.255.252
GigabitEthernet0/25 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e840.404f.db41 (bia e840.404f.db41)
  Description: crlneams2 port gi0/25
  Internet address is 172.26.1.38/30
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
  Last input never, output 22:30:37, output hang never
     76105481 packets input, 115528769880 bytes, 0 no buffer
     1293 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     5 packets output, 320 bytes, 0 underruns
no switchport
  Keepalive not set
cadet alain
One side is Auto and the other is statically configured. Do the same on the other side and tell us.
Regards.
Alain.
The interface does not have the capability of letting me hard code the speed/duplex settings. I'm pretty sure it's because of the interface having an SFP in them. The one side came up 1000/Full but was set to auto/auto. I think it just auto detected the link.
