Ethernet connection on AS2511-RJ
ebreverman
I have an AS2511-RJ terminal server and I have a hopefully easy question. I am trying to connect it to the internet using an RJ-45 ethernet cable. Where do I plug this cable into. I have an AUX port, Console port, and 16 ASYNC ports. None of these seem to be what I want. However, there is a port labeled "ethernet0" in the "sh ip interface brief." What port does this correlate to? Thanks.
Edison Ortiz
You need one of these
http://www.amazon.com/Allied-Telesyn-Centrecom-Twisted-Transceiver/dp/B0000510LT
It connects to the DB-15 AUI port
HTH,
__
Edison.
