Ethernet port not showing
joshbenadie
I am busy with section 2.1.1.5 in the packet tracer course. I am trying to identify 'to' and 'from' ports in the cloud.
The dropdown for the 'from' port says coaxial7, but the is nothing under the drop-down menu for the 'to' port.
I think I have configured everything correctly, please help I am new to this.
balaji.bandi
I am not a PT user
t we are not sure what device you need to add module to get Etherent ports as per the document.
https://www.packettracernetwork.com/features/cisco-wic-modules.html
BB
post the zipped Packet Tracer project (.pkt) file...
Martin L
In Cloud Config page, Click on Ethernet "interface"  under categories to change options; either Cable for Coax to Ethernet (or DSL for DSL modem connection).  Then go back to cable or dsl category to see interfaces there and make selection to/from port.  Ethernet port can be either in DSL or Cable category but not in both.  see my example with 2 Ethernet ports; 1 Ethernet for DSL and 1 for Cable.
Regards, ML
**Please Rate All Helpful Responses **
