10-02-2019 04:33 AM
Hi Tech People,
Could we connect third party Switches Ring (4 switches with ERP running) uplinks to Cisco Distribution/Core switches (9K).
could you share any idea, document or information regarding this design. Block diagram attached for information.
thanks in advance.
10-02-2019 06:26 AM
Not sure what vendor you are using for your ERP, but most 3rd part switch vendors can work with Cisco switches with no issues.
10-02-2019 06:48 AM
thanks for Reply,
your are right, but if ERP is not supported on Cisco switches, how thirdparty ERP ring control loops while uplink to cisco Distribution Switch. Cisco Supports RSTP/MSTP and thirdpary vendor is using ERP. Intermediate device should undertstand ERP to control Loop.
