Ethernet traffic on wrong port
tmadden
Can anyone point me in the right direction?  I'm Wiresharking from a 6509 port configured as this:
swC-1Z2#sh run int fa3/14
Load for five secs: 2%/0%; one minute: 3%; five minutes: 2%
Time source is NTP, 16:33:55.542 MDT Tue Feb 1 2011
Building configuration...
Current configuration : 120 bytes
interface FastEthernet3/14
switchport
switchport access vlan 2
switchport mode access
spanning-tree portfast
end
The problem is that I'm seeing unicast packets that are sourced and destined to MAC and IP addresses that don't belong to the PC, and in some cases are on different VLANs all together.  I've checked the MAC address table and don't see any problems in this case......
swC-1Z2#sh mac address-table address  0021.9b3c.0377
Time source is NTP, 17:13:27.813 MDT Tue Feb 1 2011
Codes: * - primary entry
  vlan   mac address     type    learn qos            ports
Supervisor:
*    2  0021.9b3c.0377   dynamic  Yes   --  Fa3/14
swC-1Z2#sh mac address-table int fa3/14
Load for five secs: 1%/0%; one minute: 3%; five minutes: 3%
Time source is NTP, 17:14:03.429 MDT Tue Feb 1 2011
But, I've got other MACs that are duplicating between VLANs.  For instance, one of my UPS's MAC is getting replicated in various VLANs...
swC-1Z1#sh mac address-table address 00c0.b771.0287
Load for five secs: 1%/0%; one minute: 2%; five minutes: 2%
Time source is NTP, 13:37:17.554 MDT Tue Feb 1 2011
Supervisor:
*  240  00c0.b771.0287   dynamic  Yes   --  Po3
*     2  00c0.b771.0287   dynamic  Yes   --  Po1
Load for five secs: 3%/1%; one minute: 2%; five minutes: 2%
Time source is NTP, 14:25:19.051 MDT Tue Feb 1 2011
Supervisor:
Load for five secs: 3%/1%; one minute: 3%; five minutes: 2%
Time source is NTP, 14:26:17.035 MDT Tue Feb 1 2011
Supervisor:
*  200  00c0.b771.0287   dynamic  Yes   --  Po3
VLANs 200 and 240 are both wireless VLANs, and I'm highly suspicious of the wireless configs and/or gear.
On the LAN there are 2 6509's port channeled to each other, 3 WLC 4402's, 7 3750 stacks with etherchannels to the 6509s or each other, and 50-ish 3550's and 3650's.
I've cleared the arp and mac-address tables on the 6509s and one of the 3750 stacks several times, and I'm having great network connectivity problems throughout the LAN.
Can incorrect multicast config do this?  I'm at my wits end.
Thanks.
Tim
Nagaraja Thanthry
The symptoms indicate that there is a physical loop somewhere in the network. You might want to see if there are any servers with dual NIC cards connected between these VLANs as sometimes, if configured incorrectly, these servers might bridge between the VLANs. Also, you might need to check if somewhere the ports between the switches are connected incorrectly i.e. an access port in one VLAN is connected to another access port on a different VLAN.
Hope this helps.
NT
