Switch seems to freeze
nikalleyne
Hi Guys,
I have a 2960 which seems to be freezing up, as in nothing can be done to access or use it. Once restarted everything is ok. Is there any suggestions on where or what I should look for to see what's going on. There is no information being sent to my logging console to suggest what is wrong.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 30:37:A6:AD:C7:00
Motherboard assembly number     : 73-12738-01
Power supply part number        : 341-0266-02
Motherboard serial number       : FOC140566VV
Power supply serial number      : DCA1402H49W
Model revision number           : A0
Motherboard revision number     : B0
Model number                    : WS-C2960-48PST-S
System serial number            : FOC1405Z745
Top Assembly Part Number        : 800-32982-01
Top Assembly Revision Number    : C0
Version ID                      : V01
CLEI Code Number                : COMFB10BRA
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960-48PST-S   12.2(50)SE3           C2960-LANLITEK9-M
hobbe
Level 7
Level 7
Could it be that the CPU is running at 100% ?
sh proc cpu
to check for heat and so on
sh env all
just 2 things to check..
good luck
Upgrade to 12.2(55)SE.  I've stopped using the entire 12.2(50) train.
jomar050485
We have a problem with switches freezing too. For us, the problem has been power. A UPS fixed the freezing issue. Flaky power may be your cause.
