EtherSwitch configuration on Cisco 2951 / CISCO Etherswitch SM-ES3G-16-P
alienkidmj12
i am trying to configure an internal trunk between router and etherswitch
however, i cannot get any traffic to flow, at the moment i am using an external cable from router to switch,
also is there some routing commands i should use ? or should it be automatic ?
im using a cisco 2951 router and CISCO Etherswitch SM-ES3G-16-P
similar issue to https://community.cisco.com/t5/switching/etherswitch-configuration-on-cisco-2921/m-p/3906547#M470980
Router config
interface GigabitEthernet2/0
ip address 1.0.0.1 255.255.255.0
interface GigabitEthernet2/0.1
encapsulation dot1Q 1 native
bridge-group 1
interface GigabitEthernet2/0.10
encapsulation dot1Q 10
bridge-group 10
interface GigabitEthernet2/0.20
encapsulation dot1Q 20
bridge-group 20
interface GigabitEthernet2/0.30
encapsulation dot1Q 30
bridge-group 30
interface BVI1
mac-address 5c83.8f03.7dc4
mtu 9014
ip address 192.168.0.102 255.255.255.0
ip virtual-reassembly in
interface BVI10
mac-address 5c83.8f03.7dc5
mtu 9014
ip address 192.168.1.102 255.255.255.0
interface BVI20
mac-address 5c83.8f03.7dc6
mtu 9014
ip address 192.168.2.102 255.255.255.0
interface BVI30
mac-address 5c83.8f03.7dc7
mtu 9014
ip address 192.168.3.102 255.255.255.0
Etherswitch Module config
interface GigabitEthernet0/17
description <== INTERNAL_TRUNK_TO_ROUTER_G1/1--DO_NOT_SHUTDOWN ==>
switchport trunk allowed vlan 1,10,20,30
switchport mode trunk
interface Vlan1
ip address 192.168.0.103 255.255.255.0
interface Vlan10
ip address 192.168.1.103 255.255.255.0
interface Vlan20
ip address 192.168.2.103 255.255.255.0
interface Vlan30
ip address 192.168.3.103 255.255.255.0
13 Replies 13
Mark Elsen
 -  What happens when the trunk is trying to get established and/or are the ports trunking or not ? At the same time post the output of show logging on both platforms when the trunk is being tried.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
how do i check to see trunk being established ?
nothing really much to go on in logging
bifrost-cisco2951sw#show logging
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 239 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 239 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 210 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (4096 bytes):
in configuration mode
Aug 11 00:10:51.494: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
Aug 11 00:10:52.500: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
Aug 11 00:13:44.450: %SYS-5-CONFIG_I: Configured from console by console
Aug 11 00:16:42.171: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
Aug 11 00:16:42.171: DHCPD: interface GigabitEthernet0/2 coming up
Aug 11 00:16:43.178: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
Aug 11 00:21:39.488: %SYS-5-CONFIG_I: Configured from console by console
Aug 11 00:22:41.136: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
Aug 11 00:22:42.143: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
Aug 11 00:25:00.630: %SYS-5-CONFIG_I: Configured from console by console
Aug 11 00:33:26.170: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
Aug 11 00:33:26.170: DHCPD: interface GigabitEthernet0/2 coming up
Aug 11 00:33:27.176: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
Aug 11 00:41:10.941: %SYS-5-CONFIG_I: Configured from console by sivesrutherfordd on vty3 (192.168.0.1)
Aug 11 00:41:40.032: %SYS-5-CONFIG_I: Configured from console by sivesrutherfordd on vty3 (192.168.0.1)
Aug 11 00:43:42.431: %SYS-5-CONFIG_I: Configured from console by console
Aug 11 00:43:45.316: %ADJ-3-RESOLVE_REQ: Adj resolve request: Failed to resolve 192.168.0.100 Vlan1
Aug 11 00:44:38.995: %SYS-5-CONFIG_I: Configured from console by sivesrutherfordd on vty3 (192.168.0.1)
Aug 11 00:49:53.517: %SYS-5-CONFIG_I: Configured from console by sivesrutherfordd on vty3 (192.168.0.1)
Aug 11 08:45:02.100: %SYS-5-CONFIG_I: Configured from console by sivesrutherfordd on vty3 (192.168.0.1)
Aug 11 08:51:05.218: DHCPD: interface Vlan10 coming up
Aug 11 08:51:07.223: %LINK-3-UPDOWN: Interface Vlan10, changed state to up
Aug 11 08:51:07.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan10, changed state to up
Aug 11 08:51:13.925: DHCPD: IP address change on interface Vlan10
Aug 11 08:51:19.856: DHCPD: interface Vlan20 coming up
Aug 11 08:51:21.861: %LINK-3-UPDOWN: Interface Vlan20, changed state to up
Aug 11 08:51:21.869: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan20, changed state to up
Aug 11 08:51:26.760: DHCPD: IP address change on interface Vlan20
Aug 11 08:51:32.145: DHCPD: interface Vlan30 coming up
Aug 11 08:51:34.150: %LINK-3-UPDOWN: Interface Vlan30, changed state to down
Aug 11 08:51:35.996: DHCPD: IP address change on interface Vlan30
Aug 11 08:51:38.454: %SYS-5-CONFIG_I: Configured from console by sivesrutherfordd on vty3 (192.168.0.1)
Aug 11 08:56:30.973: %SYS-5-CONFIG_I: Configured from console by sivesrutherfordd on vty3 (192.168.0.1)
Aug 11 08:57:04.074: %SYS-5-CONFIG_I: Configured from console by sivesrutherfordd on vty3 (192.168.0.1)
theres nothing in the logs from 2951 to be honest.
thanks
dave
bifrost-cisco2951#show interface trunk
Port Mode Encapsulation Status Native vlan
Gi2/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi2/1 1-2,10,20,1002-1005
Port Vlans allowed and active in management domain
Gi2/1 1-2
Port Vlans in spanning tree forwarding state and not pruned
Gi2/1 1-2
bifrost-cisco2951#
bifrost-cisco2951sw#show interface trunk
Gi0/1 on 802.1q trunking 1
Gi0/17 on 802.1q trunking 1
Gi0/18 on 802.1q trunking 1
Gi0/1 1,10,20,30
Gi0/17 1,10,20,30
Gi0/18 4
Gi0/1 1,10,20
Gi0/17 1,10,20
Gi0/18 none
Gi0/1 1,10,20
Gi0/17 1,10,20
Gi0/18 none
bifrost-cisco2951sw#show int GigabitEthernet0/17 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 1,10,20,30
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
bifrost-cisco2951sw#show int GigabitEthernet0/17 trunk
Gi0/17 1,10,20,30
Gi0/17 1,10,20
Gi0/17 1,10,20
bifrost-cisco2951#show int GigabitEthernet2/0 trunk
bifrost-cisco2951#
would spanning tree need to be enabled for this ?
Can you give me some help here please.
  - Just and only show the output of show int Gix/y status on both platforms.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
There is no status option available on the 2951 router
******** SWITCH
bifrost-cisco2951sw#show int GigabitEthernet0/17 status
Port Name Status Vlan Duplex Speed Type
Gi0/17 <== INTERNAL_TRUNK connected trunk full 1000 1000BaseX
******** ROUTER
bifrost-cisco2951#show int GigabitEthernet2/0 status
% Invalid input detected at '^' marker.
bifrost-cisco2951#
bifrost-cisco2951#show int GigabitEthernet2/0 summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* GigabitEthernet2/0 0 0 0 0 0 0 3000 5 0
* GigabitEthernet2/0.1 - - - - - - - - -
* GigabitEthernet2/0.10 - - - - - - - - -
* GigabitEthernet2/0.20 - - - - - - - - -
* GigabitEthernet2/0.30 - - - - - - - - -
NOTE:No separate counters are maintained for subinterfacesbifrost-cisco2951#show int GigabitEthernet2/0 trunk
bifrost-cisco2951#
i did notice that the other internal interface can be used with status
bifrost-cisco2951#show int GigabitEthernet2/1 status
Gi2/1 <== Internal switc connected trunk auto auto 10/100BaseTX
bifrost-cisco2951#
bizaire, maybe GigabitEthernet2/0 is not configured correctly to allow status option.
two interfaces on router, and two on switch - i believe they speak to each other, i wanted to use the first interface for comms.
ROUTER
bridge-group 1
bridge-group 10
bridge-group 20
bridge-group 30
interface GigabitEthernet2/1
description <== Internal switch interface connected to Service Module ==>
switchport trunk allowed vlan 1,2,10,20,1002-1005
no ip address
SWITCH
switchport nonegotiate
interface GigabitEthernet0/18
description <== MUST_BE_ENABLED_TO_PROVIDE_POWER_TO_IP_PHONES ==>
switchport trunk allowed vlan 4
bifrost-cisco2951sw#show int GigabitEthernet0/18 status
Gi0/18 <== MUST_BE_ENABLE connected trunk full 1000 1000BaseX
bifrost-cisco2951#
managed to fix it i think, but there is a speed mismatch
 - How did you fix it ? Why do you think there is a speed mismatch ?
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Hello
Glad you fixed this problem just would like to point out for future ref.
interface GigabitEthernet2/0  <---- by default  this would be your native vlan 1
bridge-group 1
bridge-group 10<----- IRB isn't required
bridge-group 20<----- IRB isn't required
bridge-group 30<----- IRB isn't required
Kind Regards
Paul
