probleme switch planet
Dhikra Marghli
Level 5
Level 5
Hello
i have a switch  switch planet  pl-igs-10020pt :
problem :
the port  switch planet ( dwon ) linked with port router Huawei ( up/dwon ):
+++port optique switch planet  ( Name: GigabitEthernet 1/10 )
IGS-10020HPT# show interface GigabitEthernet 1/10 switchport
Administrative mode: trunk
Access Mode VLAN: 1
Trunk Native Mode VLAN: 1
Administrative Native VLAN tagging: disabled
Allowed VLANs: 1-4095
Hybrid port configuration
Port Type: C-Port
Acceptable Frame Type: All
Ingress filter: Disabled
Egress tagging: All except-native
Hybrid Native Mode VLAN: 1
Hybrid VLANs Enabled: 1-4095
Access Mode VLAN: 1
Port Type: C-Port
GigabitEthernet 1/10 Capabilities:
SFP Vendor P/N: MGB-TLX
SFP Vendor S/N: AG00519202001
SFP Vendor Name: PLANET
SFP Vendor Revision: v2
SFP Type: 1000BASE_LX
Speed cap: 100,1000,auto
Duplex cap: full,auto
Trunk encap. type: 802.1Q
Trunk mode: access,hybrid,trunk
Channel: yes
Broadcast suppression: no
Flowcontrol: yes
Fast Start: no
QoS scheduling: tx-(8q)
CoS rewrite: yes
ToS rewrite: yes
UDLD: no
Inline power: no
RMirror: yes
PortSecure: yes
IGS-10020HPT# show interface GigabitEthernet 1/10 status
Interface Mode Speed & Duplex Flow Control Max Frame Excessive Link
GigabitEthernet 1/10 enabled Auto disabled 9600 Discard Down
IGS-10020HPT# show interface GigabitEthernet 1/10 status show interface GigabitEthernet 1/10 switchport  show interface GigabitEthernet 1/10 tran show interface GigabitEthernet 1/10 transceiver
Port Type Speed Wavelength(nm) Distance(m) Temperature(C) Voltage(V) Current(mA) TxPower(dBm) RxPower(dBm)
[PORT] PORT_NUM = 9 10 1000Base-LX 1000-Base 1310 20000 52.5020 3.2910 30.5280 -5.8821 1.9769
no loop-protect
no loop-protect tx-mode
switchport mode trunk
no lldp receive
no lldp transmit
spanning-tree edge
no spanning-tree auto-edge
There are all check for interface gi1/10 SO i need what configuration in this interface that allow interface UP with interface port router Huwai ( up/dwon ) !!N??????????????,
i wait e reply for this problem switch planet with router ATN950B
thanks in advance
Dhikra Marghli
Level 5
Level 5
Please , i need a help and who can understand and can give me what is configuration in switch planet that allow port UP/UP  with port router ATN950B !!!!!!!!??????
thanks in advance
