Etherswitch module and BVI
JamieThompson9945
Frequent Visitor
Frequent Visitor
Hi, Im having some trouble with switching and BVIs. Im trying to setup an AP with local switching so i need a trunk port. This is my network setup.
When I plug the AP directly into the switch below the router all the vlans work however when I have it connected to the POE modules only a single vlan will pass traffic.
When I go to the routers config page it shows that the vlans that don't pass traffic (11 and 12) are down
GigabitEthernet0/0         unassigned      YES NVRAM  up                    up
GigabitEthernet0/0.10      unassigned      YES unset  up                    up
GigabitEthernet0/0.11      unassigned      YES unset  up                    up
GigabitEthernet0/0.12      unassigned      YES unset  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
GigabitEthernet0/1/0       unassigned      YES unset  up                    up
GigabitEthernet0/1/1       unassigned      YES unset  up                    up
GigabitEthernet0/1/2       unassigned      YES unset  down                  down
GigabitEthernet0/1/3       unassigned      YES unset  down                  down
GigabitEthernet0/1/4       unassigned      YES unset  down                  down
GigabitEthernet0/1/5       unassigned      YES unset  down                  down
GigabitEthernet0/1/6       unassigned      YES unset  down                  down
GigabitEthernet0/1/7       unassigned      YES unset  down                  down
BVI10                      10.0.0.221      YES NVRAM  up                    up
BVI11                      10.0.1.10       YES NVRAM  up                    up
BVI12                      10.0.2.10       YES NVRAM  up                    up
Vlan1                      unassigned      YES unset  up                    up
Vlan10                     unassigned      YES unset  up                    up
Vlan11                     unassigned      YES unset  down                  down
Vlan12                     unassigned      YES unset  down                  down
Starting from the bottom the port connecting the switch to the router is configured as follows
interface ethernet 1/47
 jumbo frame mtu 9014
 switchport allowed vlan add 1 untagged
 switchport mode trunk
 switchport allowed vlan add 1,10-12 tagged
The router is configured as follows
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 bridge-group 10
interface GigabitEthernet0/0.11
 encapsulation dot1Q 11
 bridge-group 11
interface GigabitEthernet0/0.12
 encapsulation dot1Q 12
 bridge-group 12
interface Vlan1
 no ip address
interface Vlan10
 no ip address
 bridge-group 10
interface Vlan11
 no ip address
 bridge-group 11
interface Vlan12
 no ip address
 bridge-group 12
interface BVI10
 ip address 10.0.0.10 255.255.255.0
interface BVI11
 ip address 10.0.1.10 255.255.255.0
interface BVI12
 ip address 10.0.2.10 255.255.255.0
bridge 10 protocol ieee
bridge 10 route ip
bridge 11 protocol ieee
bridge 11 route ip
bridge 12 protocol ieee
bridge 12 route ip
Finally the POE module on the router is configured as follows.
interface GigabitEthernet0/1/0
 switchport trunk native vlan 10
 switchport trunk allowed vlan 1,2,10-12,1002-1005
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface GigabitEthernet0/1/4
 no ip address
interface GigabitEthernet0/1/5
 no ip address
interface GigabitEthernet0/1/6
 no ip address
interface GigabitEthernet0/1/7
 no ip address
The problem has to be from the router up as everything else on the network is working fine. I can ping the BVI IPs from the different vlans so that access is working. However when i connect the AP to the POE module only Vlan 10 pases traffic.
Is there something wrong with my config ?
Ok. It was the vlan database.
When I set one of the ports to an access port I got the following.
(config-if)#switchport access vlan 11
% Access VLAN does not exist. Creating vlan 11
So I went to the vlan database
after entering
vlan database
vlan 11
vlan 12
the vlans came online so it turns out they have to be created in the vlan database and the config as an interface.
Edwin Portillo
My friend,
It has also tried to allow trunking VLANs:
switchport trunk allowed vlan add 1,10-12 tagged
The switch is not a cisco and its configured for trunking (its an edgecore). I can ping the BVI interface IP addresses from devices connected to the switch on the same vlan.
Here is the sh vlans output
Virtual LAN ID:  1 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interface:   GigabitEthernet0/0
 This is configured as native Vlan for the following interface(s) :
GigabitEthernet0/0    Native-vlan Tx-type: Untagged
   Protocols Configured:   Address:              Received:        Transmitted:
GigabitEthernet0/0 (1)
        Other                                           0                  53
   227 packets, 13620 bytes input
   53 packets, 6983 bytes output
Virtual LAN ID:  10 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interface:   GigabitEthernet0/0.10
GigabitEthernet0/0.10 (10)
        Bridging        Bridge Group 10              3558                   3
        Other                                           0                 183
   10488 packets, 3624443 bytes input
   186 packets, 12780 bytes output
Virtual LAN ID:  11 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interface:   GigabitEthernet0/0.11
GigabitEthernet0/0.11 (11)
        Bridging        Bridge Group 11                46                   0
        Other                                           0                 184
   423 packets, 42957 bytes input
   184 packets, 12512 bytes output
Virtual LAN ID:  12 (IEEE 802.1Q Encapsulation)
   vLAN Trunk Interface:   GigabitEthernet0/0.12
GigabitEthernet0/0.12 (12)
        Bridging        Bridge Group 12                78                   0
        Other                                           0                 184
   644 packets, 76900 bytes input
Vlan11 is down, line protocol is down
  Hardware is EtherSVI, address is b838.6123.ffab (bia b838.6123.ffab)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not supported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 1 interface resets
     0 unknown protocol drops
CUBE#sh int vlan10
Vlan10 is up, line protocol is up
I can set the BVI11 and BVI12 interface ip address to DHCP and they do indeed get ip address's yet the vlan associated with it stays down.
Attached is the routers config.
And above Vlan 11 and 12 are down even though bvi11 and bvi 12 have got DHCP IP addresses ?]
after entering
vlan database
vlan 11
vlan 12
