Eve-NG Help Required
mkazam001
Level 3
Level 3
After following instructions for a bare metal install on an azure linux vm, I can log into the Eve GUI via Firefox & start a vPCS, however, Im unable to connect to it. Even disabled the windows firewall.
If anyone has had a similar issue, any help would be appreciated.
Regards, mk
balaji.bandi
This more related to the eve-ng question, this needs to address by eve-ng developer, not by cisco community.
it would be nice if you can post this question to a respected site forum you get an appropriate answer.
On high level here  is the requirement :
https://www.eve-ng.net/index.php/documentation/installation/system-requirement/
You connecting from Local PC to Cloud - this is a lab simulator, why not spin up a VM locally ( RDP from your PC to cloud VM for lab)
BB
eve working after re-install.
posted on cisco forum, as most of the community is very helpful.
Glad all sorted for you. now.
BB
