exanic_perf_test
rakeshrathore7827
Community Member
exanic_perf_test
why these numbers vary on every run
5 Replies 5
balaji.bandi
depends on where you testing, you need to provide more information about testing.
BB
ALL test running on same just few second gap between.
Georg Pauwen
looking at the documentation (linked below) it appears that the values returned depend a.o. on the host CPU utilization, BIOS and/or Kernel settings, which are obviously volatile. So as far as I can tell, you will never get the same values. The values returned are median latencies.
What host device are you testing on ?
https://exablaze.com/docs/exanic/user-guide/benchmarking/
@Georg Pauwen  HI , Thank You Am using all The parameter which mention on user guide . But In the first output  you can see the difference is almost half. From where I can get the output details . and Is there any tools which can help me to test latency between 2 different server or can we use exanic_perf_test for same?
and exanic_perf_test (Its roundtrip time )
anyone >?
