Unable to reach Mgmt0 via ping from VDC to VDC in Nexus 7706
DJay11
I need to access our core switch from VDCx (Core_VDC) to VDCy (Admin_VDC) via L2 via SSH. Upon pinging, getting an RTO reply. This is just once device. Should be able to access without passing through the gateway since mgmt IP is within the same subnet.
From Admin_VDC
vrf context management
ip route 0.0.0.0/0 172.26.1.1
interface mgmt0
vrf member management
ip address 172.26.1.6/24
From Core_VDC
cfs eth distribute
interface mgmt0
ip address 172.26.1.8/24
DRCORE_VDC1# ^C
DRCORE_VDC1# ping 172.26.1.6 vrf management
PING 172.26.1.6 (172.26.1.6): 56 data bytes
36 bytes from 172.26.1.8: Destination Host Unreachable
Request 0 timed out
Request 1 timed out
^C
--- 172.26.1.6 ping statistics ---
3 packets transmitted, 0 packets received, 100.00% packet loss
DRCORE_VDC1# traceroute 172.26.1.6 vrf management
traceroute to 172.26.1.6 (172.26.1.6), 30 hops max, 40 byte packets
1 DRCORE_VDC1 (172.26.1.8) 0.279 ms !H 0.221 ms !H 0.213 ms !H
DRCORE_VDC1#
balaji.bandi
it should work as expected, how is your mgmt0 interface connected ? where ?
VDC means 2 different devcies, that means, you need to have Layer 2 connectivity ?
BB
DJay11
mgmt0 is connected in the Server_VDC (Same device).
interface Ethernet5/31
description [LINK TO ADMIN_VDC]
switchport
switchport mode trunk
switchport trunk native vlan 501
no shutdown
interface Vlan501
description Management
no shutdown
ip address 172.26.1.1/24
This is just 1 physical device but different vdc.
I need to have a L2 connectivity in situation that FW is down. My only connection if ever FW is down is thru Core_VDC. No direct access to Admin_VDC in case our FW is down.
Trying to understand here, your management in VRF, that VRF need to extend to other VRF ?
BB
Yes. Need to reach vrf management 172.26.1.6 from vrf management 172.26.1.8. They are on same device but different VDC.
VDC1
interface mgmt0
VDC2
interface mgmt0
Getting an RTO when tried to ping.
