Existing hardware in cucm 6.0
John Cheetley
Level 3
Level 3
Hi Techs,
I asked this question before, however the answers I got unfortunately weren't complete.
I understand the CUCM is the platform application that automates a lot of work in the VOIP world and that the CLI appears to be very limited.
How does this recognise or discover hardware inventory like voice modules, VIC's and VWICs and others?
Is there a command line interface link for 6.0 that can be referenced?
Thanks in advance
Reza Sharifi
You may get a more accurate response if you post this in the IP Telephony section of the forum.
As far as I know you don't install voice modules, VWIC,etc.. in the CUCM.  The voice modules, and VWICs are usually installed in the voice gateway, which is usually a router. It could be 2800, 3800 or even 4000 series.
https://supportforums.cisco.com/document/90521/mgcp-gateway-integration-cucm-and-pstn-service-provider
My apologies for not replying before.
Need to find information via Cisco software advisor Tool.
Where do i find this please as I need to find platform and version of Cisco IOS software compatibility
