explain nat and routes
rajbhatt
Level 3
Level 3
Hi ,
Heres my scenerio:
Server A is conencted to router 3 also
router3
sw1---serverA 192.168.1.1
router1 Here there are 2 route maps and relevant routes to router2 and also to outside
Sw2
router2 ip nat inside source static 192.168.1.1 10.1.1.1 and specific routes
sw3
serverB 10.2.2.2
My question is traffic should go from server B to server A.
On router1
ip nat inside source route-map x pool x-Server
ip access-list extended x
permit ip any host 192.168.1.1
ip nat pool x-Server 40.40.1.2 40.40.1.3 netmask 255.255.252.0
route-map x Map permit 10
match ip address x
route 10.0.0.0 255.255.255.0 router2
On router 2
A.route 192.168.1.0 255.255.255.0 router1
B.route 10.1.1.0 255.255.255.0 router 1
My questions is
1.So when checking the routes to go from server b to server A should it check route A or B and what will be the nat
2.What should be the route it will check and nat translation it will check for the return packet
Thanks in advance
Raj
royalblues
Level 10
Level 10
what is the inside and outside interafces of the routers R1 and r2
Narayan
hi,
AS u can see from the figure r1 connects to a switch on the outside and on the inside it is conencted to a firewall
R2 is conencted to a inside of firewall and is conencted to internal networks via 2 swicthes
I just wanted to find out how the ip source natting is happening and how does it use the route table
Raj
If server B requests info from server A :
192.168.1.1 should be converted to 10.1.1.1.
It should check the route route 10.1.1.0 255.255.255.0 router 1
or should it check the route :route 192.168.1.0 255.255.255.0 router1
Because as far as i know first it ckecks route and then proceeds to translate .
My confusion here is
what should be the translation
Once it reaches router 1 it hits the router map :it takes address of 40.40 and access server
match ip address x
Traffic reaches server A
While the packet will come back :
It will just check the nat in router 1 and foward the packet based on route
Am I correct in my assumption ?Please clarify if I am wrong
I cannot understand the persence of this route ?
Thanks in advance
Raj
