explanation about bridge group
Fernando_Meza
Level 7
Level 7
Hi Netpros,
I have some problems understanding the use of the bridge-group command. I have seen it on access points to bridge the radio interfaces with the ethernet interfaces .. I have also seen this on VoIP configs such as the one attached .. but to be honest I am not exactly sure what does it do .. any comments are much appreciated
bridge irb
interface Loopback10
ip address 12.1.1.1 255.255.255.255
interface Loopback20
ip address 12.8.0.1 255.255.255.255
interface Loopback30
ip address 12.10.1.1 255.255.255.255
interface Loopback110
ip address 12.10.2.1 255.255.255.255
interface Loopback120
ip address 12.10.3.1 255.255.255.255
interface Loopback130
ip address 12.10.4.1 255.255.255.255
interface Loopback140
ip address 12.10.5.1 255.255.255.255
interface Tunnel10
no ip address
tunnel source 12.1.1.1
tunnel destination 12.1.10.1
bridge-group 10
bridge-group 10 spanning-disabled
interface Tunnel20
no ip address
tunnel source 12.8.0.1
tunnel destination 12.8.10.1
bridge-group 20
bridge-group 20 spanning-disabled
interface Tunnel30
no ip address
tunnel source 12.10.1.1
tunnel destination 12.10.11.1
bridge-group 30
bridge-group 30 spanning-disabled
interface Tunnel110
no ip address
tunnel source 12.10.2.1
tunnel destination 12.10.12.1
bridge-group 110
bridge-group 110 spanning-disabled
interface Tunnel120
no ip address
tunnel source 12.10.3.1
tunnel destination 12.10.13.1
bridge-group 120
bridge-group 120 spanning-disabled
interface Tunnel130
no ip address
tunnel source 12.10.4.1
tunnel destination 12.10.14.1
bridge-group 130
bridge-group 130 spanning-disabled
interface Tunnel140
no ip address
tunnel source 12.10.5.1
tunnel destination 12.10.15.1
bridge-group 140
bridge-group 140 spanning-disabled
interface Ethernet0/0
description *********** INTERNET CONNECTION ******************
ip address dhcp
half-duplex
no cdp enable
crypto ipsec client ezvpn ezvpnclient
interface Ethernet1/0
no ip address
half-duplex
interface Ethernet1/0.1
description HOME-VLAN
encapsulation dot1Q 1 native
interface Ethernet1/0.10
description HQ-Data
encapsulation dot1Q 10
no cdp enable
bridge-group 10
interface Ethernet1/0.20
description BR1-Data
encapsulation dot1Q 20
no cdp enable
bridge-group 20
interface Ethernet1/0.30
description BR2-Data
encapsulation dot1Q 30
no cdp enable
bridge-group 30
interface Ethernet1/0.110
description HQ_Voice
encapsulation dot1Q 110
no cdp enable
bridge-group 110
interface Ethernet1/0.120
description BR1-Voice
encapsulation dot1Q 120
no cdp enable
bridge-group 120
interface Ethernet1/0.130
description BR2-Voice
encapsulation dot1Q 130
no cdp enable
bridge-group 130
interface Ethernet1/0.140
description PSTN
encapsulation dot1Q 140
no cdp enable
bridge-group 140
23 Replies 23
Mohammed
Thank you for the kind words (and for the ratings). I enjoy cooperating with you in the forum. I have done many of these things - and tried many more in the lab. I enjoy sharing what I have learned with others and find the forums an excellent place for this exchange of knowledge.
Rick
Rick
Rick,
Thank you, you deserve more than i can say, the rating is the least thing that i could do to appreciate your knowledge and your attitude.
Take care, and have a nice day :)
BR,
Mohammed Mahmoud.
Rick,
Appreciate your expert explanation indeed .. I have followed your posts with Mohamed and things are heaps clearer now .. thank you very much for your invaluable expertise in the subject ..
Cheers,
Rick,
I have a similar scenario but the only issue is that I can not ping between the two routers doing the bridging over the ppp connection. do you happen to know why? here is what I have:
Router 1:
interface FastEthernet0
ip address 172.16.4.253 255.255.255.0
no ip route-cache
speed auto
bridge-group 1
interface Serial0
ip unnumbered FastEthernet0
encapsulation ppp
no ip route-cache
no fair-queue
service-module t1 timeslots 1-6
bridge-group 1
bridge 1 protocol ieee
Router 2:
ip address 172.16.4.254 255.255.255.0
no ip route-cache
speed auto
bridge-group 1
interface Serial0
encapsulation ppp
no ip route-cache
no fair-queue
bridge-group 1
Uriel
Because you have posted only the interface configs I can not tell how close your config really is to the original situation. In the original situation they had configured IRB but I can not tell that you have configured IRB. I suspect that this is the essence of your problem.
To do bridging of IP on an IOS router you need to do either configure IRB or configure "no ip routing" (or to configure CRB which is hardly used any more). I can not tell that you have configured IRB nor that you can configured no ip routing. Without either of these then your router will route IP on these interfaces and will bridge any non-IP traffic. But I doubt that you want to bridge non-IP traffic.
Rick
Rick
Hi Rick,
No I did not configure IRB all I'm doing is bridging since we can not implement routing in this scenario due to application constraints so the LAN subnet needs to be the same at both ends of the two routers.
Uriel.
Uriel
Ok no IRB. Is the router configured with "no ip routing"?
Also if you are not routing then I see no point in having ip unnumbered on the serial interfaces. Try removing these and see if the behavior changes.
Rick
Rick
Rick,
Yes no ip routing and I'll remove the ip unnumbered command to see if I can ping.
Hi. Sorry for reviving this old post, but i can't find a solution to this:
i have created most simple bridge example
pc1 --> R1 -->pc2
i have bridged both router ethernet ports like you described, and assigned addresses:
pc1 1.1.1.1/24 no DG
pc2 1.1.1.2/24 no DG, but i cant ping pc1 from pc2 and vice versa
ARP broadcast request is just not passing through the bridged router...
p.s.SORRY FOR BOTHERING, I'V SOLVED IT. CHEERS
