Extended traceroute not working
londint
I am entering the following on to a router and I keep getting
#traceroute
Protocol [ip]:
Target IP address: 1.1.1.1
Source address: 1.1.1.2
% Invalid source address
What am I doing wrong? Pls help. Thanks
rajib_das
may b ur subneting problem
Jon Marshall
Invalid source address usually means that the router does not have an interface with that address.
With the addresses yu are entering traceroute would report nothing as they are on the same subnet.
Jon
michal.grzelak
You must use IP address of existing IP interface (either physical or Vlan).
e.g.
interface gi 1/1
ip address 10.10.10.10 255.255.255.0
exit
So in traceroute Source address use IP address 10.10.10.10.
Please rate this post if You find it helpful.
Regards:
Michal
pat98eraser
I just hit some similar issue, with a vrf configuration:
traceroute vrf xxxx ip
and so on, vrf won't be defined with an ip option but before "ip"
Hope that help.
Patrice
