Extented ACL
Samus1984
Hi everyone,
I need your help.
My Vlans 1, 2 and 3 must be able to communicate with each other and with the dns server. However, there must be no communication from Vlans 1,2,3 to vlan 4.
On the other hand, vlan 4 must be able to communicate with everyone.
I've tried to turn the problem in all directions but I can't do the second part when vlan 4 must communicate with vlans 1,2,3.
Before making my ACLs I took care to make my encapsulations well and everyone can have access to everyone else.
balaji.bandi
Look at the recent discussion : ( try your effort and create a ACL and test)
https://community.cisco.com/t5/network-management/acl-vlan/m-p/4731628
Still not working post your ACL config and what test you have done ?
BB
The requirement that vlan 4 can successfully communicate with vlans 1, 2, 3 but that vlans 1, 2, 3 can not communicate with vlan 4 gets tricky. The first attempt would probably be an extended acl that specifies that if the source is vlan 1 and the destination is vlan 4 then the packet should be denied. The problem with this is that if some device in vlan 4 sends a request to some device in vlan 1 and the device in vlan 1 attempts to send a response that the response matches the deny statement in the acl and communication for vlan 4 to vlan 1 fails. Note that for tcp traffic there is a solution to this which is using the established parameter for tcp in the acl. But for non tcp protocols there is not a good solution.
For this requirement to work it is not enough to just look at source and destination of a packet. We need to keep track of who initiated the connection. If vlan 4 is the initiator then permit the traffic. If vlan 1 was the initiator then deny the traffic. The best way to accomplish this is to use some device that does stateful inspection.
Rick
Solved: Re: ACL Vlan - Cisco Community
I solve same issue week ago
check my solution
Hello
This could be accomplished for tcp traffic using an access-list matching on established traffic initiated from vlan 4 however for UDP as it connectionless you would be only able to deny or allow such connection with an access-list.
Example:
Ip access-list extended denyvlans
permit tcp 10.0.1.0.0 0.0.0.255 any established
deny tcp 10.0.1.0.0 0.0.0.255 any
permit tcp 10.0.2.0.0 0.0.0.255 any established
deny tcp 10.0.2.0.0 0.0.0.255 any
permit tcp 10.0.3.0.0 0.0.0.255 any established
deny tcp 10.0.3.0.0 0.0.0.255 any
deny udp 10.0.1.0.0 0.0.0.255 any
deny udp 10.0.2.0.0 0.0.0.255 any
deny udp 10.0.3.0.0 0.0.0.255 any
permit ip any any
int vlan 4
ip access-group denyvlans out
Kind Regards
Paul
