Problem with archive download-sw
Niklas.D
So i have a bunch of 2960-X  (WS-C2960X-48FPS-L) and i am trying to upgrade the IOS via SCP.
archive download-sw scp://admin:Password@192.168.5.149/c2960x-universalk9-tar.152-7.E4.tar
Could not buffer tarfile...using multiple downloads
examining image...!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Premature end of tar file
%Error opening flash:update/info (No such file or directory)
ERROR: Image is not a valid IOS image archive.
if a re-run the command it sometimes works.
but it takes to long maybe there is a solution to this?
15 Replies 15
Leo Laohoo
Do this: delete /f /r flash:update
And then try the "archive download-sw" again.
Hi leo, thank you for the replay!
2960-STACK#dir
Directory of flash:/
2 -rwx 2072 Aug 30 2021 12:46:29 +02:00 multiple-fs
3 -rwx 1644 Mar 22 2021 10:33:32 +01:00 vlan.dat
4 -rwx 60237 Aug 30 2021 12:46:28 +02:00 config.text
5 -rwx 32137 Oct 20 2016 11:00:19 +02:00 config.text.backup
7 -rwx 1924 Oct 20 2016 11:00:20 +02:00 private-config.text.backup
8 drwx 512 Feb 28 2016 11:07:52 +01:00 c2960x-universalk9-mz.152-2.E3
673 drwx 512 Feb 28 2016 11:07:53 +01:00 dc_profile_dir
675 -rwx 1924 Aug 30 2021 12:46:29 +02:00 private-config.text
122185728 bytes total (94979072 bytes free)
MOSCXAE01-2960-STACK#del
MOSCXAE01-2960-STACK#delete /fr
MOSCXAE01-2960-STACK#delete /for
MOSCXAE01-2960-STACK#delete /force /re
MOSCXAE01-2960-STACK#delete /force /recursive flash:update/info
Still the same problem (and there is no update/Info)
Hold on.  Wait a second.  Why are the output have two different hostnames?
2960/2960G, 2960L, 2960S and 2960X have set-specific IOS filename.  2960X firmware will only be accepted by the 2960X/2960XR.
The above error message?  This is an "insurance policy".  This is a "friend" looking-out-for-you and making sure someone is not trying to use a wrong IOS file.
Hi Leo,
here i am working on the same switch and it behaves like the othere switch also.
i have cut a few of the !!! so they are longer.
MOSCXCE02#archive download-sw scp://login:pass@1.1.1.1/c2960x-universalk9-tar.152-7.E4.tar
extracting c2960x-universalk9-mz.152-7.E4/info (688 bytes)
extracting info (110 bytes)
Stacking Version Number: 1.160
System Type: 0x00000000
Ios Image File Size: 0x01989A00
Total Image File Size: 0x02799A00
Minimum Dram required: 0x08000000
Image Suffix: universalk9-152-7.E4
Image Directory: c2960x-universalk9-mz.152-7.E4
Image Name: c2960x-universalk9-mz.152-7.E4.bin
Image Feature: IP|LAYER_2|SSH|3DES|MIN_DRAM_MEG=128
FRU Module Version: No FRU Version Specified
Old image for switch 1: unknown
Old image for switch 2: unknown
Extracting images from archive into flash on switch 1...
c2960x-universalk9-mz.152-7.E4/ (directory)
c2960x-universalk9-mz.152-7.E4/html/ (directory)!
c2960x-universalk9-mz.152-7.E4/html/day0/ (directory)
c2960x-universalk9-mz.152-7.E4/html/day0/features/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/index.html (6044 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/app.js (629 bytes)
c2960x-universalk9-mz.152-7.E4/html/day0/lib/ (directory)
c2960x-universalk9-mz.152-7.E4/html/day0/lib/lodash/ (directory)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/lib/lodash/lodash.compat.js (251175 bytes)!!!!!!!!!!!!!!!!!!!!!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/config.js (74 bytes)
c2960x-universalk9-mz.152-7.E4/html/day0/js/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/js/requestRoutingHandler.js (1461 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/js/deviceCommunicator.js (25344 bytes)!!!
c2960x-universalk9-mz.152-7.E4/html/day0/resources/ (directory)
c2960x-universalk9-mz.152-7.E4/html/day0/resources/styles/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/resources/styles/main.css (44692 bytes)!!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/resources/styles/custom.css (8805 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/resources/styles/angular-wizard.css (11822 bytes)!
c2960x-universalk9-mz.152-7.E4/html/day0/odm/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/odm/showAccessPorts.odm (409 bytes)
c2960x-universalk9-mz.152-7.E4/html/day0/wizard/ (directory)
c2960x-universalk9-mz.152-7.E4/html/day0/wizard/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/views/step2.html (11854 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/views/summaryScreen.html (11667 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/views/dayzeroView.html (5577 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/views/step4.html (5275 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/views/step1.html (8402 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/views/custom.html (1342 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/views/wifiView.html (21953 bytes)!!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/views/step3.html (4467 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/dayzeroController.js (14932 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/day0/wizard/StepCtrls/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/StepCtrls/step1Ctrl.js (9858 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/StepCtrls/step2Ctrl.js (22230 bytes)!!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/StepCtrls/step4Ctrl.js (6978 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/StepCtrls/summaryScreenCtrl.js (29092 bytes)!!!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/StepCtrls/step3Ctrl.js (6424 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/StepCtrls/wifiCtrl.js (15977 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/wizard/StepCtrls/dayZeroStepService.js (6406 bytes)!
c2960x-universalk9-mz.152-7.E4/html/day0/utilities/ (directory)
c2960x-universalk9-mz.152-7.E4/html/day0/utilities/megamenu/ (directory)
c2960x-universalk9-mz.152-7.E4/html/day0/utilities/megamenu/images/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/megamenu/images/ciscoprime.png (5150 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/megamenu/images/inspur_logo.png (36754 bytes)!!!
c2960x-universalk9-mz.152-7.E4/html/day0/utilities/directives/ (directory)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/directives/angular-wizard.js (10763 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/directives/validationDirective.js (2848 bytes)
c2960x-universalk9-mz.152-7.E4/html/day0/utilities/filters/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/filters/customFilter.js (117 bytes)
c2960x-universalk9-mz.152-7.E4/html/day0/utilities/services/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/services/validationDirective.js (2488 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/services/validationService.js (28269 bytes)!!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/services/capabilityService.js (3987 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/services/commonServices.js (41997 bytes)!!!!
c2960x-universalk9-mz.152-7.E4/html/day0/utilities/jsons/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/utilities/jsons/onlinehelp.json (2769 bytes)
c2960x-universalk9-mz.152-7.E4/html/day0/nls/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/day0/nls/ApplicationProperties-zh.json (36498 bytes)!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/nls/ApplicationProperties-ja.json (49091 bytes)!!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/nls/ApplicationProperties-en.json (40711 bytes)!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/day0/nls/ApplicationProperties-ko.json (44865 bytes)!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/express-setup.htm (17876 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/utils/ (directory)
c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/ (directory)
c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/Thumbs.db (3584 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/option-white.svg (882 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/wired-white.svg (6439 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/directions-white.svg (2921 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/megamenu_background.png (713 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/ciscoprime.png (5150 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/pin-white.svg (1116 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/chevron-down.svg (2180 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/inspur_logo.png (36754 bytes)!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/add.svg (2877 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/pin.svg (2352 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/wifi-white.svg (3836 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/directions.svg (2915 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/help.svg (991 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/monitoring-white.svg (4401 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/images/chevron-right-white.svg (2199 bytes)
c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/css/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/css/style.css (10390 bytes)!
c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/ (directory)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/menu_2960CX_2960plus.json (4072 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/menu_C1000.json (4237 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/menu_2960plus.json (3964 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/menu_CDB_2960L_2960plus.json (4072 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/menu_C1000SM.json (4112 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/menu_2960L_SM.json (4243 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/menu_2960L.json (4369 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/menu_2960X.json (4345 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/helper/menu.json (4481 bytes)!
c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/megaMenu/ (directory)
c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/megaMenu/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/megaMenu/views/megaMenu.html (857 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/megaMenu/views/submenus.html (1299 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/megamenu/megaMenu/megaMenuCtrl.js (5933 bytes)!
c2960x-universalk9-mz.152-7.E4/html/utils/footer/ (directory)
c2960x-universalk9-mz.152-7.E4/html/utils/directives/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/directives/toggleButtonDirective.js (2172 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/directives/commonDirectives.js (3810 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/directives/angular-wizard.js (10474 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/directives/addEditDirective.js (19149 bytes)!!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/directives/validationDirective.js (2488 bytes)
c2960x-universalk9-mz.152-7.E4/html/utils/filters/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/filters/customFilter.js (126 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/filters/translateFilter.js (442 bytes)
c2960x-universalk9-mz.152-7.E4/html/utils/header/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/header/headerCtrl.js (23585 bytes)!!!
c2960x-universalk9-mz.152-7.E4/html/utils/header/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/header/views/header.html (4986 bytes)
c2960x-universalk9-mz.152-7.E4/html/utils/services/ (directory)!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/services/datasourceService.js (30852 bytes)!!!
extracting c2960x-universalk9-mz.152-7.E4/html/utils/services/validationService.js (2365 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/services/commonServices.js (93886 bytes)!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/utils/jsons/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/utils/jsons/onlinehelp.json (2769 bytes)!
c2960x-universalk9-mz.152-7.E4/html/utils/factories/ (directory)
c2960x-universalk9-mz.152-7.E4/html/macros/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/macros/extractMacro (74 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/express-setup.html (17876 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/vlan/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/vlan/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/vlan/views/vlanView.html (39820 bytes)!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/features/vlan/vlanController.js (90021 bytes)!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/qos/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/qos/qosController.js (53144 bytes)!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/qos/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/qos/views/qosView.html (23632 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/routingProtocol/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/routingProtocol/routingProtocolController.js (125857 bytes)!!!!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/routingProtocol/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/routingProtocol/views/routingProtocolView.html (43247 bytes)!!!!
c2960x-universalk9-mz.152-7.E4/html/features/system/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/system/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/system/views/systemView.html (55528 bytes)!!!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/features/system/systemController.js (139790 bytes)!!!!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/management/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/management/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/management/views/managementView.html (37802 bytes)!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/features/management/managementController.js (82660 bytes)!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/common/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/common/switch/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/switch/switchController.js (10394 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/common/switch/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/switch/views/switchView.html (4653 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/switch/switchService.js (20023 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/common/switch/resource/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/switch/resource/switch.css (6244 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/common/swupdate/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/swupdate/swupdateCtrl.js (16728 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/common/swupdate/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/swupdate/views/swupdate.html (2453 bytes)
c2960x-universalk9-mz.152-7.E4/html/features/common/examples/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/examples/exampleControllers.js (4638 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/common/examples/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/examples/views/gridView.html (331 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/examples/views/accordionView.html (1146 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/examples/views/tabsView.html (4222 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/common/todo/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/todo/todo.html (322 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/todo/wip.png (4972 bytes)
c2960x-universalk9-mz.152-7.E4/html/features/common/db/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/common/db/CPUMemory/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/common/db/CPUMemory/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/CPUMemory/views/CPUMemoryView.html (1797 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/CPUMemory/CPUMemoryController.js (8137 bytes)
c2960x-universalk9-mz.152-7.E4/html/features/common/db/dashlet/ (directory)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/dashlet/dashlets.json (1741 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/dashlet/DashletService.js (12759 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/common/db/dashlet/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/dashlet/views/modal1.html (1586 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/dashlet/views/dashlet.html (1432 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/dashlet/index.html (1284 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/dashlet/dashletDirectives.js (6999 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/dashlet/DashletController.js (11942 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/common/db/cl/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/cl/criticalLogController.js (9066 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/common/db/cl/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/cl/views/criticalLogView.html (718 bytes)
c2960x-universalk9-mz.152-7.E4/html/features/common/db/sysInfo/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/common/db/sysInfo/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/sysInfo/views/systemInfoView.html (1570 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/db/sysInfo/systemInfoCtrl.js (8381 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/common/stackConf/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/stackConf/switchController.js (23231 bytes)!!!
c2960x-universalk9-mz.152-7.E4/html/features/common/stackConf/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/stackConf/views/switchView.html (10641 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/stackConf/switchService.js (40667 bytes)!!!!
c2960x-universalk9-mz.152-7.E4/html/features/common/stackConf/resource/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/common/stackConf/resource/switch.css (5026 bytes)
c2960x-universalk9-mz.152-7.E4/html/features/energySaver/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/energySaver/energySaverController.js (36464 bytes)!!!!
c2960x-universalk9-mz.152-7.E4/html/features/energySaver/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/energySaver/views/energySaverView.html (10585 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/rmon/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/rmon/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/rmon/views/rmonView.html (8583 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/rmon/rmonController.js (13872 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/acl/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/acl/aclController.js (96395 bytes)!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/acl/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/acl/views/aclView.html (35881 bytes)!!!!
c2960x-universalk9-mz.152-7.E4/html/features/span/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/span/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/span/views/spanView.html (12200 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/span/spanController.js (38473 bytes)!!!!
c2960x-universalk9-mz.152-7.E4/html/features/netFlow/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/netFlow/netFlowCtrl.js (36259 bytes)!!!!
c2960x-universalk9-mz.152-7.E4/html/features/netFlow/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/netFlow/views/netFlow.html (7656 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/aaa/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/aaa/aaaController.js (78725 bytes)!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/aaa/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/aaa/views/aaaView.html (33186 bytes)!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/features/aaa/aaaService.js (23986 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/poe/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/poe/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/poe/views/poe.html (10203 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/poe/poeController.js (27928 bytes)!!!
c2960x-universalk9-mz.152-7.E4/html/features/configureCli/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/configureCli/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/configureCli/views/configureCli.html (5565 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/configureCli/configCliCtrl.js (14058 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/troubleShoot/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/troubleShoot/troubleShootController.js (53228 bytes)!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/troubleShoot/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/troubleShoot/views/troubleShootView.html (29874 bytes)!!!
c2960x-universalk9-mz.152-7.E4/html/features/commands/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/commands/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/commands/views/commandsView.html (469 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/commands/commandsController.js (328 bytes)
c2960x-universalk9-mz.152-7.E4/html/features/clients/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/clients/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/clients/views/clientsMonitorView.html (762 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/clients/clientsMonitorController.js (14929 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/userAdmin/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/userAdmin/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/userAdmin/views/userAdministrationView.html (5082 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/userAdmin/userAdministrationController.js (12389 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/portsConfig/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/portsConfig/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/portsConfig/views/portsConfigView.html (81054 bytes)!!!!!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/features/portsConfig/portsConfDataService.js (10702 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/portsConfig/portsConfController.js (192742 bytes)!!!!!!!!!!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/portsMonitor/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/portsMonitor/portsMonitorController.js (60886 bytes)!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/portsMonitor/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/portsMonitor/views/portsMonitorView.html (3417 bytes)
c2960x-universalk9-mz.152-7.E4/html/features/help/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/help/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/help/views/supportView.html (2429 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/features/help/views/documentationView.html (2331 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/features/help/helpController.js (6748 bytes)!
c2960x-universalk9-mz.152-7.E4/html/features/stp/ (directory)
c2960x-universalk9-mz.152-7.E4/html/features/stp/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/stp/views/stpView.html (65964 bytes)!!!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/features/stp/stpDataService.js (28733 bytes)!!!
extracting c2960x-universalk9-mz.152-7.E4/html/features/stp/stpController.js (97815 bytes)!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/features/staticRouting/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/staticRouting/staticRoutingController.js (23791 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/features/staticRouting/views/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/features/staticRouting/views/staticRoutingView.html (12917 bytes)!!
c2960x-universalk9-mz.152-7.E4/html/tests/ (directory)
c2960x-universalk9-mz.152-7.E4/html/tests/common/ (directory)
c2960x-universalk9-mz.152-7.E4/html/tests/dataset/ (directory)
c2960x-universalk9-mz.152-7.E4/html/tests/dataset/common/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/logout.html (5845 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/index.html (8229 bytes)
c2960x-universalk9-mz.152-7.E4/html/onlinehelp/ (directory)!
extracting c2960x-universalk9-mz.152-7.E4/html/app.js (13832 bytes)!
c2960x-universalk9-mz.152-7.E4/html/lib/ (directory)
c2960x-universalk9-mz.152-7.E4/html/lib/bootstrap/ (directory)
c2960x-universalk9-mz.152-7.E4/html/lib/bootstrap/css/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/bootstrap/css/bootstrap.min.css (155758 bytes)!!!!!!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/lib/bootstrap/js/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/bootstrap/js/bootstrap.min.js (131637 bytes)!!!!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/lib/ngDraggable/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/ngDraggable/ngDraggable.js (27976 bytes)!!!
c2960x-universalk9-mz.152-7.E4/html/lib/less/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/less/less.min.js (142067 bytes)!!!!!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/lib/kendo/ (directory)
c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/kendo.dataviz.bootstrap.min.css (4275 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/kendo.bootstrap.min.css (421187 bytes)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/sprite_kpi_2x.png (1472 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/markers.png (1014 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/loading.gif (847 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/imagebrowser.png (6215 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/sprite.png (13986 bytes)!!
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/editor.png (2873 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/slider-h.gif (63 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/loading-image.gif (2588 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/markers_2x.png (2285 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/indeterminate.gif (2115 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/sprite_2x.png (35023 bytes)!!!!
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/slider-v.gif (63 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/sprite_kpi.png (787 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/Bootstrap/loading_2x.gif (2220 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/kendo.dataviz.min.css (4265 bytes)!
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/styles/kendo.common-bootstrap.min.css (216825 bytes)!!!!!!!!!!!!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/lib/kendo/js/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/js/kendo.angular.min.js (22033 bytes)!!
extracting c2960x-universalk9-mz.152-7.E4/html/lib/kendo/js/kendo.all.min.js (3148771 bytes)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
c2960x-universalk9-mz.152-7.E4/html/lib/lang/ (directory)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/lang/ko_lang.js (1368 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/lang/zh_lang.js (1499 bytes)
extracting c2960x-universalk9-mz.152-7.E4/html/lib/lang/scrypt.js (246427 bytes)!!!!!!!!!
Extracting images from archive into flash...
Warning: Unable to allocate memory to display the tar extraction of files,
however upgrade process is still continuing. If you would like to
see the tar extraction output, try upgrading one switch at a time.
%Error opening flash1:update/info (Bad file number)
Error: Unable to extract image for switch 1. Some systems may
Error: have been left in an inconsistent state.
ERROR: Malformed `info' file.
You are not being consistent.  Look at the start of the thread and compare this with the last.  The error messages are different.  One is talking about a stand-alone switch and this one talks about a switch stack.
I cannot and will not troubleshoot this issue if the stories are getting swapped around.
Hi Leo.
Yes that was another switch.
i get this problem on alot of my 2960-X, working on other models IE-3000/2000 works fine.
I dont think i said it was not a stack.
but its mixed Stack none-Stack (they allways have a stack module), both the outputs are from stacks.
MOSCXAE01-2960-STACK#archive download-sw scp://login:pass@.149/c2960x-universalk9-tar.152-7.E4.tar
MOSCXAE01-2960-STACK#archive download-sw scp://login:pass@1.1.1.1/c2960x-universalk9-tar.152-7.E4.tar
extracting info (110 bytes)!!!!!!!!!!!!!!!!!
MOSCXAE01-2960-STACK#dir
MOSCXAE01-2960-STACK#sh ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 26-Aug-15 07:12 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(3r)E1, RELEASE SOFTWARE (fc1)
MOSCXAE01-2960-STACK uptime is 4 years, 47 weeks, 6 days, 1 hour, 12 minutes
System restarted at 10:43:42 MET-DST Fri Oct 21 2016
System image file is "flash:/c2960x-universalk9-mz.152-2.E3/c2960x-universalk9-mz.152-2.E3.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-48FPS-L (APM86XXX) processor (revision L0) with 524288K bytes of memory.
Processor board ID FCW2009A3AK
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
156 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:CA:E5:63:23:80
Motherboard assembly number : 73-16691-04
Power supply part number : 341-0527-01
Motherboard serial number : FOC200862MR
Power supply serial number : DCB200361WZ
Model revision number : L0
Motherboard revision number : B0
Model number : WS-C2960X-48FPS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC20090XUS
System serial number : FCW2009A3AK
Top Assembly Part Number : 68-100469-01
Top Assembly Revision Number : B0
Version ID : V04
CLEI Code Number : CMMLN00ARC
Daughterboard revision number : A0
Hardware Board Revision Number : 0x18
Switch Ports Model SW Version SW Image
1 52 WS-C2960X-48FPS-L 15.2(2)E3 C2960X-UNIVERSALK9-M
2 52 WS-C2960X-48FPS-L 15.2(2)E3 C2960X-UNIVERSALK9-M
* 3 52 WS-C2960X-48FPS-L 15.2(2)E3 C2960X-UNIVERSALK9-M
Switch 01
Switch Uptime : 4 years, 47 weeks, 6 days, 1 hour, 50 minutes
Base ethernet MAC Address : 00:CA:E5:74:CA:80
Motherboard serial number : FOC20092U71
Power supply serial number : DCB200166RR
Daughterboard serial number : FOC20090XNW
System serial number : FCW2009A3BR
Top assembly part number : 68-100469-01
Top assembly revision number : B0
Version ID : V04
Switch 02
Base ethernet MAC Address : 04:2A:E2:7B:AE:80
Motherboard serial number : FOC20106T79
Power supply serial number : DCB200661YW
Daughterboard serial number : FOC201113HY
System serial number : FCW2011B3V1
Version ID : V04
Configuration register is 0xF
MOSCXAE01-2960-STACK#archive download-sw scp://login:pass@1.1.1.1149/c2960x-universalk9-tar.152-7.E4.tar
MOSCXAE01-2960-STACK uptime is 4 years, 47 weeks, 6 days, 1 hour, 44 minutes
export@cisco.com.
Version ID : V04
Switch 01
Switch Uptime : 4 years, 47 weeks, 6 days, 2 hours, 22 minutes
Version ID : V04
Switch 02
Version ID : V04
MOSCXAE01-2960-STACK#archive download-sw scp://login:pass@1.149/c2960x-universalk9-tar.152-7.E4.tar
MOSCXAE01-2960-STACK#dir dc_profile_dir
Directory of flash:/dc_profile_dir/
674 -rwx 180863 Feb 28 2016 11:07:53 +01:00 dc_default_profiles.txt
MOSCXAE01-2960-STACK#sh clock
13:59:46.523 MET-DST Mon Sep 20 2021
MOSCXAE01-2960-STACK#dir ?
/all List all files
/recursive List files recursively
all-filesystems List files on all filesystems
bs: Directory or file name
cns: Directory or file name
flash1: Directory or file name
flash2: Directory or file name
flash3: Directory or file name
flash: Directory or file name
null: Directory or file name
nvram: Directory or file name
system: Directory or file name
tar: Directory or file name
tmpsys: Directory or file name
xmodem: Directory or file name
ymodem: Directory or file name
| Output modifiers
<cr>
MOSCXAE01-2960-STACK#dir /all
MOSCXAE01-2960-STACK#dir c2960x-universalk9-mz.152-2.E3
Directory of flash:/c2960x-universalk9-mz.152-2.E3/
9 -rwx 786 Feb 28 2016 10:56:14 +01:00 info
10 drwx 6144 Feb 28 2016 10:56:19 +01:00 html
672 -rwx 21270528 Feb 28 2016 10:59:05 +01:00 c2960x-universalk9-mz.152-2.E3.bin
MOSCXAE01-2960-STACK#sh flas
MOSCXAE01-2960-STACK#sh flash
MOSCXAE01-2960-STACK uptime is 4 years, 47 weeks, 6 days, 3 hours, 7 minutes
export@cisco.com.
Version ID : V04
Switch 01
Switch Uptime : 4 years, 47 weeks, 6 days, 3 hours, 46 minutes
Version ID : V04
examining image...
Old image for switch 1: flash1:/c2960x-universalk9-mz.152-2.E3
Old image will be deleted before download.
Old image for switch 2: flash2:/c2960x-universalk9-mz.152-2.E3
Old image for switch 3: flash:/c2960x-universalk9-mz.152-2.E3
Deleting `flash1:/c2960x-universalk9-mz.152-2.E3' to create required space
Deleting `flash2:/c2960x-universalk9-mz.152-2.E3' to create required space
Extracting images from archive into flash on switch 2...
Deleting `flash:/c2960x-universalk9-mz.152-2.E3' to create required space
Installing (renaming): `flash1:/update/c2960x-universalk9-mz.152-7.E4' ->
`flash1:/c2960x-universalk9-mz.152-7.E4'
EDS file download on SKU match in progress...
New software image installed in flash1:/c2960x-universalk9-mz.152-7.E4
Installing (renaming): `flash2:/update/c2960x-universalk9-mz.152-7.E4' ->
`flash2:/c2960x-universalk9-mz.152-7.E4'
New software image installed in flash2:/c2960x-universalk9-mz.152-7.E4
Installing (renaming): `flash:update/c2960x-universalk9-mz.152-7.E4' ->
`flash:/c2960x-universalk9-mz.152-7.E4'
New software image installed in flash:/c2960x-universalk9-mz.152-7.E4
Deleting old files from dc profile dir "flash1:/dc_profile_dir"
extracting dc profile file from "flash1:/c2960x-universalk9-mz.152-7.E4/dc_default_profiles.txt" to "flash1:/dc_profile_dir/dc_default_profiles.txt"
Deleting old files from dc profile dir "flash2:/dc_profile_dir"
extracting dc profile file from "flash2:/c2960x-universalk9-mz.152-7.E4/dc_default_profiles.txt" to "flash2:/dc_profile_dir/dc_default_profiles.txt"
Deleting old files from dc profile dir "flash:/dc_profile_dir"
extracting dc profile file from "flash:/c2960x-universalk9-mz.152-7.E4/dc_default_profiles.txt" to "flash:/dc_profile_dir/dc_default_profiles.txt"
All software images installed.
It is the WAN link.
Try using "/image" option so it does not have to upload the HTML files.
Hi, yes its over a WAN link
Dont think so, dont have any kinda off package lost, or buffer and its running on 2.000  Mbit/s Usage is around 40 Mbits. so i think that is fine.
Also a week ago i was doing the same upgrades in my Datacenter, the 2960 in the Datacenter would fail but a IE3000 and a 3560CX would run the same command and work perfect. (none of them are stacked)
Same error it just fails when runing the /imageonly
"archive download-sw /imageonly scp://XXXXX"
Ok, last trick:  Find a PC at the remote site.  ANY PC will do.
Drop the TAR file into that PC and install TFPTd32/TFTPd64.
Point to that PC.
Not on site today, but will be tomorow, will try that then! Will post update then!
Thank you leo
Mark Elsen
 - Check the integrity of the software-distribution-file by verifying the md5sum.
 M.
Hi Marce, thank you for the reply
its the correct md5sum
I know I'm coming in late here, but just in case anyone else runs into this...
The below is a common Notification, and doesn't prevent you from upgrading the stack.  Just reboot the stack, or the offending member.
"Warning: Unable to allocate memory to display the tar extraction of files,
see the tar extraction output, try upgrading one switch at a time."
If for some weird reason that doesn't work, try using the archive commands separately from the tftp command.
Example:
# Start HTTP Webserver on File Server
  python3 -m http.server 80
# Copy Image
copy http://1.2.3.4/downloads/c2960x-universalk9-tar.152-7.E4.tar  flash:c2960x-universalk9-tar.152-7.E4.tar
# Install Image
archive download-sw /overwrite /reload flash:c2960x-universalk9-tar.152-7.E4.tar
Btw, HTTP is waaaaay faster the TFTP.  I've seen people change the block size to help speed it up TFTP, but even Cisco Devnet Team uses HTTP to transfer files. Might save you some time in the future.
--Jody
