External ip redirect on my cisco 861 (port 80)
yvesetjeanlouis
I have a little problem with a redirection.
When I type my external ip, I am directly connected to my Cisco 861 ( through port 80 (HTTP))
Even if I do a factory default, I always have the same problem.
I try to make another redirection on another internal ip , but always same problem...
Someone should have an idea?
Thank you very much.
7 Replies 7
Gregory Snipes
Level 4
Level 4
Are you trying to setup a static PAT port translation AKA port forwarding? If so you would need to use something like this "ip nat inside source static tcp x.x.x.x 80 x.x.x.x 80" to map the outside port 80 to the proper inside PC.
Thank for your answer.  I tried it but it's always the same problem.
But I was wondering if it should not be a rule ACL??
Thank you for your help
You may also need a firewall hole to permit the traffic though. Could you post up a scrubbed config and the output of a "sh ip nat translation" command. This may help pinpoint your troubles.
Here is :
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.2.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
ip ddns update ccp_ddns1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname fd085234@SKYNET
ppp chap password 7 1430171901052C2276
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.2.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner exec ^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Cisco#sh ip nat translation
Pro Inside global      Inside local       Outside local      Outside global
tcp 91.177.161.5:49293 192.168.2.5:49293  42.121.103.194:80  42.121.103.194:80
tcp 91.177.161.5:49294 192.168.2.5:49294  42.121.103.194:80  42.121.103.194:80
tcp 91.177.161.5:49295 192.168.2.5:49295  210.51.33.117:80   210.51.33.117:80
tcp 91.177.161.5:49296 192.168.2.5:49296  210.51.33.117:80   210.51.33.117:80
tcp 91.177.161.5:49297 192.168.2.5:49297  42.121.103.194:80  42.121.103.194:80
tcp 91.177.161.5:49298 192.168.2.5:49298  42.121.103.194:80  42.121.103.194:80
udp 91.177.161.5:49461 192.168.2.5:49461  8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:52808 192.168.2.5:52808  8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:54222 192.168.2.5:54222  8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:62986 192.168.2.5:62986  8.8.8.8:53         8.8.8.8:53
tcp 91.177.161.5:32866 192.168.2.6:32866  173.194.34.2:443   173.194.34.2:443
tcp 91.177.161.5:33066 192.168.2.6:33066  173.194.34.2:443   173.194.34.2:443
tcp 91.177.161.5:33664 192.168.2.6:33664  54.248.250.207:5223 54.248.250.207:522
tcp 91.177.161.5:33985 192.168.2.6:33985  173.194.34.0:443   173.194.34.0:443
tcp 91.177.161.5:34904 192.168.2.6:34904  74.125.132.188:5228 74.125.132.188:522
8
tcp 91.177.161.5:36631 192.168.2.6:36631  173.194.34.7:80    173.194.34.7:80
tcp 91.177.161.5:36845 192.168.2.6:36845  173.194.34.6:443   173.194.34.6:443
tcp 91.177.161.5:36891 192.168.2.6:36891  173.194.34.14:443  173.194.34.14:443
tcp 91.177.161.5:37155 192.168.2.6:37155  173.194.34.15:443  173.194.34.15:443
tcp 91.177.161.5:38351 192.168.2.6:38351  173.194.34.2:80    173.194.34.2:80
tcp 91.177.161.5:41758 192.168.2.6:41758  173.194.45.94:443  173.194.45.94:443
tcp 91.177.161.5:41942 192.168.2.6:41942  173.194.45.94:443  173.194.45.94:443
tcp 91.177.161.5:43814 192.168.2.6:43814  173.194.45.94:443  173.194.45.94:443
tcp 91.177.161.5:43940 192.168.2.6:43940  173.194.45.94:443  173.194.45.94:443
tcp 91.177.161.5:44108 192.168.2.6:44108  173.194.34.0:443   173.194.34.0:443
tcp 91.177.161.5:44567 192.168.2.6:44567  173.194.34.6:443   173.194.34.6:443
tcp 91.177.161.5:46957 192.168.2.6:46957  173.194.45.94:443  173.194.45.94:443
tcp 91.177.161.5:48555 192.168.2.6:48555  173.194.34.2:443   173.194.34.2:443
tcp 91.177.161.5:48735 192.168.2.6:48735  173.194.34.14:443  173.194.34.14:443
tcp 91.177.161.5:50534 192.168.2.6:50534  54.240.162.122:80  54.240.162.122:80
tcp 91.177.161.5:53078 192.168.2.6:53078  54.248.250.207:5223 54.248.250.207:522
tcp 91.177.161.5:53249 192.168.2.6:53249  173.194.45.94:443  173.194.45.94:443
tcp 91.177.161.5:54819 192.168.2.6:54819  173.194.34.2:443   173.194.34.2:443
tcp 91.177.161.5:55483 192.168.2.6:55483  173.194.78.188:5228 173.194.78.188:522
8
tcp 91.177.161.5:56055 192.168.2.6:56055  173.194.34.2:443   173.194.34.2:443
tcp 91.177.161.5:57770 192.168.2.6:57770  54.248.250.207:5223 54.248.250.207:522
tcp 91.177.161.5:57797 192.168.2.6:57797  176.34.104.204:80  176.34.104.204:80
tcp 91.177.161.5:57847 192.168.2.6:57847  216.137.63.8:80    216.137.63.8:80
tcp 91.177.161.5:58599 192.168.2.6:58599  173.194.34.9:80    173.194.34.9:80
tcp 91.177.161.5:59170 192.168.2.6:59170  173.194.34.14:443  173.194.34.14:443
tcp 91.177.161.5:60765 192.168.2.6:60765  173.194.34.0:443   173.194.34.0:443
tcp 91.177.161.5:63892 192.168.2.8:63892  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63893 192.168.2.8:63893  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63895 192.168.2.8:63895  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63896 192.168.2.8:63896  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63897 192.168.2.8:63897  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63898 192.168.2.8:63898  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63899 192.168.2.8:63899  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63900 192.168.2.8:63900  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63901 192.168.2.8:63901  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63902 192.168.2.8:63902  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63903 192.168.2.8:63903  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63904 192.168.2.8:63904  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:63905 192.168.2.8:63905  72.246.94.134:80   72.246.94.134:80
tcp 91.177.161.5:52376 192.168.2.12:52376 2.16.216.201:80    2.16.216.201:80
tcp 91.177.161.5:52378 192.168.2.12:52378 2.16.216.200:80    2.16.216.200:80
tcp 91.177.161.5:52379 192.168.2.12:52379 2.16.216.200:80    2.16.216.200:80
tcp 91.177.161.5:49760 192.168.2.30:49760 173.194.78.105:80  173.194.78.105:80
tcp 91.177.161.5:49761 192.168.2.30:49761 173.194.78.125:5222 173.194.78.125:522
tcp 91.177.161.5:49762 192.168.2.30:49762 173.194.34.1:443   173.194.34.1:443
tcp 91.177.161.5:49763 192.168.2.30:49763 173.194.34.1:443   173.194.34.1:443
tcp 91.177.161.5:49764 192.168.2.30:49764 173.194.78.95:443  173.194.78.95:443
tcp 91.177.161.5:49765 192.168.2.30:49765 173.194.78.94:80   173.194.78.94:80
tcp 91.177.161.5:49766 192.168.2.30:49766 173.194.34.15:443  173.194.34.15:443
tcp 91.177.161.5:49767 192.168.2.30:49767 173.194.78.94:443  173.194.78.94:443
tcp 91.177.161.5:49768 192.168.2.30:49768 173.194.34.12:443  173.194.34.12:443
tcp 91.177.161.5:49769 192.168.2.30:49769 173.194.78.105:443 173.194.78.105:443
tcp 91.177.161.5:49770 192.168.2.30:49770 173.194.34.29:443  173.194.34.29:443
tcp 91.177.161.5:49771 192.168.2.30:49771 173.194.34.11:443  173.194.34.11:443
tcp 91.177.161.5:49772 192.168.2.30:49772 173.194.34.10:443  173.194.34.10:443
tcp 91.177.161.5:49773 192.168.2.30:49773 173.194.34.22:443  173.194.34.22:443
tcp 91.177.161.5:49774 192.168.2.30:49774 173.194.34.26:443  173.194.34.26:443
tcp 91.177.161.5:49775 192.168.2.30:49775 173.194.34.10:443  173.194.34.10:443
tcp 91.177.161.5:49776 192.168.2.30:49776 173.194.34.26:443  173.194.34.26:443
tcp 91.177.161.5:49777 192.168.2.30:49777 173.194.34.29:443  173.194.34.29:443
tcp 91.177.161.5:49778 192.168.2.30:49778 173.194.34.6:443   173.194.34.6:443
tcp 91.177.161.5:49779 192.168.2.30:49779 173.194.34.12:443  173.194.34.12:443
tcp 91.177.161.5:49783 192.168.2.30:49783 173.194.34.15:443  173.194.34.15:443
tcp 91.177.161.5:49798 192.168.2.30:49798 173.194.34.15:443  173.194.34.15:443
tcp 91.177.161.5:49799 192.168.2.30:49799 173.194.34.15:443  173.194.34.15:443
tcp 91.177.161.5:49801 192.168.2.30:49801 74.125.228.111:443 74.125.228.111:443
tcp 91.177.161.5:56180 192.168.2.30:56180 173.194.78.125:5222 173.194.78.125:522
udp 91.177.161.5:58698 192.168.2.30:58698 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:58885 192.168.2.30:58885 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59364 192.168.2.30:59364 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59414 192.168.2.30:59414 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59576 192.168.2.30:59576 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59636 192.168.2.30:59636 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59839 192.168.2.30:59839 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59915 192.168.2.30:59915 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59954 192.168.2.30:59954 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59967 192.168.2.30:59967 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60104 192.168.2.30:60104 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60305 192.168.2.30:60305 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60378 192.168.2.30:60378 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60403 192.168.2.30:60403 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60435 192.168.2.30:60435 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60537 192.168.2.30:60537 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60635 192.168.2.30:60635 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60777 192.168.2.30:60777 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60789 192.168.2.30:60789 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60974 192.168.2.30:60974 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60988 192.168.2.30:60988 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:61075 192.168.2.30:61075 8.8.8.8:53         8.8.8.8:53
tcp 91.177.161.5:1485  192.168.2.30:61185 199.9.252.102:843  199.9.252.102:843
tcp 91.177.161.5:4210  192.168.2.33:4210  91.177.240.178:10005 91.177.240.178:10
005
tcp 91.177.161.5:80    192.168.2.50:80    ---                ---
tcp 91.177.161.5:3389  192.168.2.150:3389 196.211.19.82:54058 196.211.19.82:5405
8
tcp 91.177.161.5:3389  192.168.2.150:3389 ---                ---
Cisco#
So yes you would need to forward the port "ip nat inside source static tcp 192.168.2.X 80 interface Dialer0 80" where X is the last octet of the device you want.
Then a "clear ip nat translation forced" would be a good idea (may be disruptive).
Thank you,
I tried it now...
But... Same problem :-(...
Cisco#show ip nat translation
tcp 91.177.161.5:50789 192.168.2.5:50789  217.149.68.26:80   217.149.68.26:80
tcp 91.177.161.5:50814 192.168.2.5:50814  123.125.115.126:80 123.125.115.126:80
tcp 91.177.161.5:50919 192.168.2.5:50919  173.194.34.25:80   173.194.34.25:80
tcp 91.177.161.5:50977 192.168.2.5:50977  173.194.41.143:80  173.194.41.143:80
tcp 91.177.161.5:51005 192.168.2.5:51005  110.75.146.112:80  110.75.146.112:80
udp 91.177.161.5:63740 192.168.2.5:63740  8.8.8.8:53         8.8.8.8:53
tcp 91.177.161.5:50173 192.168.2.30:50173 173.194.34.8:443   173.194.34.8:443
tcp 91.177.161.5:50185 192.168.2.30:50185 173.194.34.26:80   173.194.34.26:80
tcp 91.177.161.5:50186 192.168.2.30:50186 173.194.34.25:80   173.194.34.25:80
tcp 91.177.161.5:50187 192.168.2.30:50187 173.194.34.25:80   173.194.34.25:80
tcp 91.177.161.5:50188 192.168.2.30:50188 173.194.34.9:80    173.194.34.9:80
tcp 91.177.161.5:50190 192.168.2.30:50190 173.194.34.26:80   173.194.34.26:80
tcp 91.177.161.5:50196 192.168.2.30:50196 173.194.34.25:443  173.194.34.25:443
tcp 91.177.161.5:50198 192.168.2.30:50198 173.194.78.94:443  173.194.78.94:443
tcp 91.177.161.5:50201 192.168.2.30:50201 2.16.84.176:443    2.16.84.176:443
tcp 91.177.161.5:50218 192.168.2.30:50218 2.16.84.176:443    2.16.84.176:443
tcp 91.177.161.5:50226 192.168.2.30:50226 80.239.178.216:80  80.239.178.216:80
tcp 91.177.161.5:50227 192.168.2.30:50227 80.239.178.216:80  80.239.178.216:80
tcp 91.177.161.5:50228 192.168.2.30:50228 80.239.178.216:80  80.239.178.216:80
tcp 91.177.161.5:50229 192.168.2.30:50229 80.239.178.216:80  80.239.178.216:80
tcp 91.177.161.5:50230 192.168.2.30:50230 80.239.178.216:80  80.239.178.216:80
tcp 91.177.161.5:50231 192.168.2.30:50231 80.239.178.216:80  80.239.178.216:80
tcp 91.177.161.5:50232 192.168.2.30:50232 2.16.216.153:80    2.16.216.153:80
tcp 91.177.161.5:50233 192.168.2.30:50233 2.16.216.153:80    2.16.216.153:80
tcp 91.177.161.5:50234 192.168.2.30:50234 2.16.216.153:80    2.16.216.153:80
tcp 91.177.161.5:50252 192.168.2.30:50252 199.38.165.156:80  199.38.165.156:80
tcp 91.177.161.5:50266 192.168.2.30:50266 173.194.34.15:443  173.194.34.15:443
tcp 91.177.161.5:50272 192.168.2.30:50272 173.194.34.13:80   173.194.34.13:80
tcp 91.177.161.5:50273 192.168.2.30:50273 173.194.34.13:80   173.194.34.13:80
tcp 91.177.161.5:50287 192.168.2.30:50287 173.194.34.2:443   173.194.34.2:443
tcp 91.177.161.5:50291 192.168.2.30:50291 173.194.34.24:443  173.194.34.24:443
tcp 91.177.161.5:50292 192.168.2.30:50292 173.194.34.11:443  173.194.34.11:443
tcp 91.177.161.5:50294 192.168.2.30:50294 173.194.78.99:443  173.194.78.99:443
tcp 91.177.161.5:50301 192.168.2.30:50301 72.163.10.15:443   72.163.10.15:443
tcp 91.177.161.5:50304 192.168.2.30:50304 50.19.253.92:443   50.19.253.92:443
tcp 91.177.161.5:50305 192.168.2.30:50305 50.19.253.92:443   50.19.253.92:443
tcp 91.177.161.5:50306 192.168.2.30:50306 50.19.253.92:443   50.19.253.92:443
tcp 91.177.161.5:50307 192.168.2.30:50307 50.19.253.92:443   50.19.253.92:443
tcp 91.177.161.5:50310 192.168.2.30:50310 184.73.185.69:443  184.73.185.69:443
tcp 91.177.161.5:50311 192.168.2.30:50311 184.73.185.69:443  184.73.185.69:443
tcp 91.177.161.5:50312 192.168.2.30:50312 184.73.185.69:443  184.73.185.69:443
tcp 91.177.161.5:50313 192.168.2.30:50313 79.125.7.17:443    79.125.7.17:443
tcp 91.177.161.5:50314 192.168.2.30:50314 79.125.7.17:443    79.125.7.17:443
tcp 91.177.161.5:50315 192.168.2.30:50315 79.125.7.17:443    79.125.7.17:443
tcp 91.177.161.5:50321 192.168.2.30:50321 54.240.166.83:443  54.240.166.83:443
tcp 91.177.161.5:50322 192.168.2.30:50322 54.240.166.83:443  54.240.166.83:443
tcp 91.177.161.5:50323 192.168.2.30:50323 173.252.73.52:443  173.252.73.52:443
tcp 91.177.161.5:50324 192.168.2.30:50324 95.101.124.214:443 95.101.124.214:443
tcp 91.177.161.5:50325 192.168.2.30:50325 95.101.124.214:443 95.101.124.214:443
tcp 91.177.161.5:50326 192.168.2.30:50326 95.101.124.214:443 95.101.124.214:443
tcp 91.177.161.5:50327 192.168.2.30:50327 95.101.124.214:443 95.101.124.214:443
tcp 91.177.161.5:50328 192.168.2.30:50328 95.101.124.214:443 95.101.124.214:443
tcp 91.177.161.5:50329 192.168.2.30:50329 95.101.124.214:443 95.101.124.214:443
tcp 91.177.161.5:50330 192.168.2.30:50330 2.16.84.176:443    2.16.84.176:443
tcp 91.177.161.5:50331 192.168.2.30:50331 2.16.84.176:443    2.16.84.176:443
tcp 91.177.161.5:50332 192.168.2.30:50332 2.16.84.176:443    2.16.84.176:443
tcp 91.177.161.5:50333 192.168.2.30:50333 2.16.84.176:443    2.16.84.176:443
tcp 91.177.161.5:50335 192.168.2.30:50335 2.20.239.139:443   2.20.239.139:443
tcp 91.177.161.5:50336 192.168.2.30:50336 95.100.139.120:443 95.100.139.120:443
tcp 91.177.161.5:50342 192.168.2.30:50342 8.23.224.110:80    8.23.224.110:80
tcp 91.177.161.5:50344 192.168.2.30:50344 173.194.34.25:80   173.194.34.25:80
tcp 91.177.161.5:50345 192.168.2.30:50345 173.194.34.25:80   173.194.34.25:80
tcp 91.177.161.5:50346 192.168.2.30:50346 173.194.34.26:80   173.194.34.26:80
tcp 91.177.161.5:50347 192.168.2.30:50347 173.194.34.26:80   173.194.34.26:80
tcp 91.177.161.5:50348 192.168.2.30:50348 173.194.34.26:80   173.194.34.26:80
tcp 91.177.161.5:50349 192.168.2.30:50349 173.194.34.26:80   173.194.34.26:80
tcp 91.177.161.5:50350 192.168.2.30:50350 173.194.34.0:80    173.194.34.0:80
tcp 91.177.161.5:50351 192.168.2.30:50351 8.23.224.110:80    8.23.224.110:80
tcp 91.177.161.5:50352 192.168.2.30:50352 173.194.34.26:443  173.194.34.26:443
tcp 91.177.161.5:50353 192.168.2.30:50353 8.23.224.110:80    8.23.224.110:80
tcp 91.177.161.5:50354 192.168.2.30:50354 173.194.34.9:80    173.194.34.9:80
tcp 91.177.161.5:50355 192.168.2.30:50355 173.194.40.15:80   173.194.40.15:80
tcp 91.177.161.5:50356 192.168.2.30:50356 2.20.239.139:443   2.20.239.139:443
tcp 91.177.161.5:50357 192.168.2.30:50357 2.20.239.139:443   2.20.239.139:443
tcp 91.177.161.5:50358 192.168.2.30:50358 54.240.166.83:443  54.240.166.83:443
tcp 91.177.161.5:50359 192.168.2.30:50359 54.240.166.83:443  54.240.166.83:443
tcp 91.177.161.5:50360 192.168.2.30:50360 54.240.166.83:443  54.240.166.83:443
tcp 91.177.161.5:50361 192.168.2.30:50361 2.16.216.121:443   2.16.216.121:443
tcp 91.177.161.5:50362 192.168.2.30:50362 2.16.216.121:443   2.16.216.121:443
tcp 91.177.161.5:50363 192.168.2.30:50363 2.16.216.121:443   2.16.216.121:443
tcp 91.177.161.5:50364 192.168.2.30:50364 72.163.10.15:443   72.163.10.15:443
tcp 91.177.161.5:50365 192.168.2.30:50365 72.163.10.15:443   72.163.10.15:443
tcp 91.177.161.5:50366 192.168.2.30:50366 23.45.194.110:443  23.45.194.110:443
tcp 91.177.161.5:50367 192.168.2.30:50367 23.45.194.110:443  23.45.194.110:443
tcp 91.177.161.5:50368 192.168.2.30:50368 23.45.194.110:443  23.45.194.110:443
tcp 91.177.161.5:50369 192.168.2.30:50369 23.45.194.110:443  23.45.194.110:443
tcp 91.177.161.5:50370 192.168.2.30:50370 23.45.194.110:443  23.45.194.110:443
udp 91.177.161.5:58874 192.168.2.30:58874 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:58923 192.168.2.30:58923 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59058 192.168.2.30:59058 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59675 192.168.2.30:59675 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:59879 192.168.2.30:59879 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60194 192.168.2.30:60194 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60386 192.168.2.30:60386 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60755 192.168.2.30:60755 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60823 192.168.2.30:60823 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60850 192.168.2.30:60850 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60919 192.168.2.30:60919 8.8.8.8:53         8.8.8.8:53
udp 91.177.161.5:60969 192.168.2.30:60969 8.8.8.8:53         8.8.8.8:53
005
tcp 91.177.161.5:80    192.168.2.150:80   8.23.224.110:7339  8.23.224.110:7339
tcp 91.177.161.5:80    192.168.2.150:80   ---                ---
Cisco#
