10-10-2011 06:04 AM - edited 03-07-2019 02:42 AM
Dears good morning!
I Have this Card With 48 Interfaces and an interface burned and the other sequence also stops working. Why this happend?
Thanks;
Solved! Go to Solution.
10-10-2011 07:06 AM
If the ports/module failed, then just RMA the modules to Cisco if you have SmartNet Contract
10-10-2011 07:19 AM
Silvo,
If you don't have SmartNet, don't need ports 1 to 8 and don't have the funding to buy a new module then you can continue using what you have (ports 9 to 48)
10-10-2011 03:08 PM
sounds like the ASIC for ports 1 through 8 also has an issue that kicks in when port 1 fails.
10-11-2011 07:41 AM
ports per group. groups are usually handled by 1 asic.
10-10-2011 07:06 AM
10-10-2011 07:11 AM
Reza, I Don´t!
For you to understand, the interfaces does not work from 1 to 8, but 9 to 48 is working.
Thanks!
10-10-2011 07:19 AM
Silvo,
10-10-2011 07:40 AM
Only one interface was fail, but always 1 to 8 it´s not work more.
So I just wanted endender so happened!
Thanks!
10-10-2011 02:32 PM
Don't understand.
Can you post the output for the command "sh interface
10-10-2011 03:08 PM
10-10-2011 06:43 PM
Oh yes, thanks for your help! Please do you have a link where explain about this?
Thanks!
10-11-2011 07:41 AM
