failed icmp-jitter test
Hello experts,
I am trying to measure delay-jitter values of my cisco switch and i am using icmp-jitter to measure it.
I can succesfully measure  the jitter values the devices in my network but even if i successfully icmp-echo to 8.8.8.8 i cant reach 8.8.8.8 with icmp-jitter. The reason why i try to test 8.8.8.8 is to reach far distances and monitor the values.  I can provide any information if its necessary .
My successfull operations :
IPSLA operation id: 2
Type of operation: icmp-jitter
Latest RTT: 1 milliseconds
Latest operation start time: 07:09:17 UTC Fri Jul 19 2024
Latest operation return code: OK
RTT Values:
Number Of RTT: 10 RTT Min/Avg/Max: 1/1/1 milliseconds
Latency one-way time:
Number of Latency one-way Samples: 0
Source to Destination Latency one way Min/Avg/Max: 0/0/0 milliseconds
Destination to Source Latency one way Min/Avg/Max: 0/0/0 milliseconds
Jitter Time:
Number of SD Jitter Samples: 9
Number of DS Jitter Samples: 9
Source to Destination Jitter Min/Avg/Max: 0/0/0 milliseconds
Destination to Source Jitter Min/Avg/Max: 0/1/1 milliseconds
Over Threshold:
Number Of RTT Over Threshold: 0 (0%)
Packet Late Arrival: 0
Out Of Sequence: 0
Source to Destination: 0 Destination to Source 0
In both Directions: 0
Packet Skipped: 0 Packet Unprocessed: 0
Packet Loss: 0
Loss Periods Number: 0
Loss Period Length Min/Max: 0/0
Inter Loss Period Length Min/Max: 0/0
Number of successes: 217
Number of failures: 0
Operation time to live: Forever
IPSLA operation id: 5
Latest RTT: 23 milliseconds
Latest operation start time: 07:08:51 UTC Fri Jul 19 2024
Thank you for your time .
Kind Regards ,
17 Replies 17
Okay , thanks for your guidance and time .
You give up
I was busy last two days I will check ypur issue with you today
NTP server you use external?
MHM
Thank you
no it is internal
