Failover Configuration in Cisco Router
goutam_04
I have two Servers in different Networks and all the users need to access the server. When one server will be down the user's traffic will be forwarded to another servers. I need this solution in router level and with configuration of Nating. Please find the low level diagram.
5 Replies 5
Marwan ALshawi
how many routers u have, i mean connected to those servers?
satish_zanjurne
Level 4
Level 4
Hi ,
If you have not got any information follow the below link.
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_slb.html
Michael.Tuggle
goutam_04
Did you happen to find a solution to your scenario? I am looking at the same scenario.
As mentioned in the previous message, the only IOS feature that will perform this function is Server Load Balancing (SLB). This is only supported in a limited number of platforms and IOS versions (www.cisco.com/go/fn)
Additionally, SLB is in the process of being deprecated from IOS, so the future for laod balancing will be ACE.
HTH.
