FAN PS-2 NOT Present
kittenpiggy
Hi NetPro,
i have noticed that the FAN PS-2 is not present , is that a way to resolve this ?
sh env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is NOT PRESENT
TEMPERATURE is OK
Temperature Value: 38 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-1100WAC    LIT14240HHZ  OK              Good     Good     1100/0
1B  Not Present
2A  C3KX-PWR-1100WAC    LIT14240HMF  OK              Good     Good     1100/0
2B  Not Present
3A  C3KX-PWR-1100WAC    LIT14240HMD  OK              Good     Good     1100/0
3B  Not Present
4A  C3KX-PWR-1100WAC    LIT14240HPG  OK              Good     Good     1100/0
4B  Not Present
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
2   Not Present     <>
3   Not Present     <>
4   Not Present     <>
Jack
Leo Laohoo
I believe this is an IOS bug.
hobbe
Level 7
Level 7
FAN PS-2 = The fan of Powersupply 2 is not present.
The reason that the fan of PS2 is not present is that the powersupply in slot 1B is not present.
So its a kind of stupid message telling you that the fan in powersupply 1B is not responding properly to an "I am ok" signal.
But how could it ? There is no powersupply in 1B. No powersupply=no fan installed, no fan installed = no "I am ok" signal.
so it is kind of a "bug" that it does not state "not installed"
I think it have something to do with that it would be hard to know if the PS-2 or the fan in PS-2 is not installed or just broken in a way that no signal is responded to.
Good luck
