Fanless POE L3 switch
reashad
Hi All,
For my home automation i am looking for a layer 3 switch that meets the following criteria. Currently using 3750 but having issues for the last couple of days. Any suggestion will be appreciated.
1. Fanless (for quiet operation)
2.PoE (for surveillance cameras)
3. End of life models or the models about to reach EoL (they are cheap to buy from used market)
4. 1G copper ports
5. Layer 3
6. 24 ports
Please suggest the models that will match the points above
Leo Laohoo
3560CX with IP Base license.
Thanks for your reply.
I forgot to mention that i also need 24 ports.
Then buy 2 of them because unfortunately I think you will not find a fanless L3 switch with 24 ports from Cisco.
