Fast ethernet admin down although no manul shut done
santoshdpawar
Hi Guys,
I am seeing error logs on Cisco 871 router for POE although router has no POE module. After search in forums it was observed to cosmetic bug. Below are the logs :
esw_dtc_ltc4258_reg_write: no acknowlege from POE
esw_mrvl_pdc_hardware_config failed on slot 0/0
But at the same time the fast ethernet port was observed to be ADMIN down although there was no manual shut/unshut done.
%LINK-5-CHANGED: Interface FastEthernet4, changed state to administratively down
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to up
Router has ADVIPSERVICESK9-12.4(6)T. Did any one come across such issue ?
Best regards,
Santosh
santoshdpawar
Found the issue. IOS shutting/disabling the interface as it is renewing IP address (DHCP renew). Nothing can be done for this though
