Fast ethernet module for cisco-1720
ekomursito
Dear all.
My office have 3 cisco-1720 routers,
connected to the WAN backbone by using WIC-1ADSL One ADSL port module.
Recently, the WAN backbone has been upgraded to Gigabyte/Fast Ethernet system.
So I'm looking for the fast ethernet module for 1720 routers.
Unfortunatelly, the catalog said only WIC-1ENET One 10 Base-T Ethernet module is available.
Please suggest the solution so we can still use these small and reliable routers.
TIA.
7 Replies 7
Hi amit & suresh.
I had read the refered manual too, but
I did not explain may question quite well.
Allow me to describe it again.
The 1720 router has:
- One built-in 10/100MBps Fast Ethernet port
- Two modular racks
The built-in fast ethernet has been connected to our LAN. On the other side,
one of the modular rack contains the ADSL module, which is connected to our WAN.
{ADSL WAN}-----------[(ADSL module)- 1720 - (10/100BASE-T)]----{LAN}
Now we want to connect to a fast ethernet WAN like this
{Fast Ethernet WAN}-----[(FastEthernet)- 1720 - (10/100BASE-T)]----{LAN}
Thus I need a "module", that should be inserted into the modular rack to replace the ADSL module.
Hope my problem is clearer now.
TIA
There is a WIC-4ESW a 4 port 10/100 module avalable but is is only supported in 1721 routers and above. It is not supported on 1720.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/prod_release_note09186a00801c46b3.html#wp254230
The only solution you are left with is to use WIC-1ENET card or just go ahead and replace the router with a new 1800 series router.
HTH,
-amit singh
All right, I knew it :(
Thanks for the answer.
I got the bullet to ask the purchasing manager ;-)
Sureshdank
Yes you can have Fast Ethernet ports, but not GB ports. Below link may clear your doubts.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00800920ec.html
Hope that helps.
Suresh Jain
Hi Suresh,
Could you please explain your above post with respect to the requirement by the original poster.
"Yes you can have Fast Ethernet ports, but not GB ports"
Please explain
-amit singh
Amit I posted my comments when I saw the orginal post b thinking that we wanted GB ports for ethernet connectivity.
I did not see his Second post which has posted after seeing your comments.
After seeing his second post I came to know that I misunderstood his problem.
Suresh Jain
